Suspension parts list? - Mustang Evolution
Old 02-02-2014, 08:32 AM   #1
TreyDeluxe's Avatar
OK so I know that my lower ball joints are slowly going out due to the annoying squeaking noise when ever I go over a bump or push down on my fenders. So Ive decided to go ahead and update my entire front susupension system
I consider myself mechanically inclined (aircraft mechanic) but I just dont know the names of the parts I need/want to replace
So basically what Im looking for is a list of parts that would be smart to go ahead and replace/update while Im down there.
TreyDeluxe is offline   Reply With Quote
Old 02-02-2014, 08:18 PM   #2
samuelsmith's Avatar
Check tie rods and wheel bearings. Lift the car up and press up, down, and side to side to see if the bearings are good. You have upper and lower ball joints. Which are bad?
Old 02-02-2014, 09:14 PM   #3
2000stanguy's Avatar
While your in there you might want to do lowering springs and shocks. When I put mine in I had 2 broken springs.
Performance Red 2000 v6- m112 supercharger,42lb green top injectors, 310lph fuel pump, BBK shorty headers, True dual exhaust, strut tower brace, GT rear sway bar, Steeda triax short throw shifter, SR lowering springs, tinted headlights and foglights, polk audio speakers, MTX subwoofer, Kenwood head unit and black leather interior.
2000stanguy is offline   Reply With Quote
Old 02-03-2014, 05:06 AM   #4
TreyDeluxe's Avatar
Didnt know there were also upper but pretty sure its the lower, they are at the end of the a-arm directly behind the rotors. When I look under there they are dirty/rusty looking and I spray them with some lube and they stop squeaking for about a week.
Front end appearaance, or suspension mods? Can't decide OrganDonor 2011-2014 Mustang GT 14 12-28-2012 08:08 AM
Ordered some parts dudeitsdylan 2005-2010 V6 Mustang 18 11-16-2012 09:34 PM
Performance parts combination? fordmustangv6 2011-2014 V6 Mustang 29 11-07-2012 09:28 PM
03:42 PM
