Alfredo - Mustang Evolution
Old 02-03-2014, 06:42 AM   #1
Alfredo
When I pull in and shift into neutral, the revs stay at around 1300 for quite a long time, then slowly drop down to idle at about 900.
It is also noticeable when decelerating - it doesn't seem to lose speed as quickly as it should at first.
It is a 2000 Mustang V6 3.8 manual .
Is this normal, advice appreciated.
Many thanks.
Alfredo is offline   Reply With Quote
Old 02-03-2014, 10:53 AM   #2
JetLife 01GT's Avatar
Alfredo
This is the gt section. I'm guessing your car is stick. When I'm driving, if I shift to neutral my rpms do not drop to below 1k until I am almost at a complete stop and they hang around 1.1-.2k. 1.3k may be just slightly high but ur also in a v6 so idk. Maybe check ur iac. But in general for ur rpms to hang just slightly and then drop to idle is normal
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 02-03-2014, 11:57 AM   #3
Mile high JDF's Avatar
The RPMs hang to an extent when you are coasting in order to provide an adequate amount of vacuum for the Hydro-boost system to operate. Now when you say they slowly come down, how long does that take? Are you sitting still for a decent amount of time before it drops to idle?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-03-2014, 11:59 AM   #4
Moved to Pre 2005 V6 Tech section
Old 02-03-2014, 12:38 PM   #5
Much appreciated - cheers.
Old 02-03-2014, 12:42 PM   #6
If I pull into a service area and stop, the revs will remain at 1300 for say 20 seconds then take maybe 5 seconds to fall to idle speed.
Old 02-07-2014, 07:29 AM   #7
sam62893's Avatar
Have you cleaned your throttle body or idle air control valve lately. The could be dirty. Or your maf sensor
Alfredo Alfredo New Member Introductions & Greetings 13 02-20-2014 02:16 PM
04:34 AM
