How much better is traction with a t lok? - Mustang Evolution
Old 02-03-2014, 09:12 PM   #1
TorchRed03's Avatar
Region: Nebraska
I can chirp into second gear real good in my tuned auto with 245 nittos, if a got a t lok (no gear swap) do you think my tires would stay planted? What if I threw 3:73s in?
2003 Mustang
intake, exhaust, tune
TorchRed03 is offline   Reply With Quote
Old 02-03-2014, 11:22 PM   #2
lemons95's Avatar
My 4.2 when I still had the stock 2.73 open diff would peel out for quite awhile if I wanted it to. When I swapped in a 8.8 with 3.27's it grabs almost instantly and pulls. A lot more traction than I had before.
When it was raining I floored it while doing about 10, and it spun the tires.
I like how it grabs and pulls instantly. Helps at the drag strip.
Old 02-03-2014, 11:39 PM   #3
It's almost twice mo' betta...
Old 02-06-2014, 09:53 PM   #4
keaton12's Avatar
Is it worth buying gears for an auto?
keaton12 is offline   Reply With Quote
Old 02-07-2014, 12:54 PM   #5
lemons95's Avatar
Yeah its worth it. Why wouldn't it be. The gears put more torque to wheels. You loose top speed and some mpg's, and gain acceleration. It'll also go up hills easier.
Old 02-07-2014, 01:17 PM   #6
keaton12's Avatar
3.73 or 4.10?
Old 02-07-2014, 01:21 PM   #7
lemons95's Avatar
If you don't care about mpgs and just want acceleration/performance get the 4.10s. I wouldn't even look at the 3.73's. If you wanted good mpg's you can get 2.73's or 3.27's. When I had 2.73's I averaged 28 mpgs on a trip and that was going over a bunch of hills and turns.
Old 02-07-2014, 03:09 PM   #8
samuelsmith's Avatar
If you have a auto get 4.10s. If you have a standard the option is yours. You will burn more gas on the interstate with 4.10s on a standard. You will burn more gas period. But the difference is noticeable as the rpms climb.
8.8 10-14% faster/ 5-6% more gas
8.8 with 3.73-4.10s 20-24% faster/10-12% more gas
Basically the gears keep you in the powerband
Old 02-07-2014, 05:20 PM   #9
lemons95's Avatar
A standard has a steeper overdrive. It will always get better mpgs.
Old 02-07-2014, 09:33 PM   #10
keaton12's Avatar
So it'll be best to get gears and an 8.8 rear
ABS light + traction control doesnt work RedGT04 1996-2004 Mustang GT 16 11-12-2015 06:43 PM
Help me get traction! Luna1994 General Mustang Discussion 16 01-15-2014 02:44 PM
Traction Issues 12' Roush Stage 3 TheRoadWarrior 2011-2014 Mustang GT 4 01-13-2014 09:09 AM
Help diagnose! TCS / Traction Lights GWraith 2011-2014 Mustang GT 9 05-21-2013 10:36 AM
Installing a Traction Control WolfLust 2005-2010 V6 Mustang 10 10-13-2011 09:16 AM
12:22 PM
