95 mustang 5.0 - Mustang Evolution
Old 02-05-2014, 09:39 PM   #1
95 mustang 5.0
So I got a 95 mustang and the engine went bad on it.. I'm looking at a 302 5.0 v8 and I was wondering.. will I need to replace the Tranny too or could I keep the original one?? Plz help me out!
95stangking45 is offline   Reply With Quote
Old 02-05-2014, 10:01 PM   #2
samuelsmith's Avatar
Only 2 years will work. but I can not remember which 2 years
Old 02-05-2014, 10:03 PM   #3
I'm looking at a 85 I have it I'm just wondering if it will fit i don't have the money for a new tranny so hopefully this fits
Old 02-07-2014, 02:00 PM   #4
lemons95's Avatar
All of the 3.8/4.2 use the small block bolt pattern as the small block 302/351 v8. The transmission will bolt up and will work. How long though is the question. I've heard the auto transmission is bullet proof, I don't know how it would handle a v8. I do have an old 5.0 that makes less power than the current v6 though. That would be pointless to swap in a weaker engine just to to have more cylinders.
Old 02-07-2014, 02:01 PM   #5
I'm thinking about putting a v6 back in it and throwing on a turbo?
Old 02-07-2014, 02:04 PM   #6
lemons95's Avatar
Also the engine mounts and kmember from your 85 will fit in your 95. I recommend buying a 94 or 95 mustang transmission and bell housing. They changed them for the 94/95 5.0's.
If you really want to make power you should get a 351 block, the 302 block cracks around 400hp, the 351 cracks around 700 hp, and can be stroked up to a 427.(302 can be stroked up to a 347)
Old 02-07-2014, 02:13 PM   #7
I could get a 302 but idk if it will for my t5 tranny? And id need all knew wiring
Old 02-07-2014, 03:00 PM   #8
That is the weakness of the motor. People sell stroker kits for the 5.0. And some times the block cracks. I don't know how to tell if you have a weak block.
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
FJ Cruiser to Mustang 5.0 AveryPlaysBass 2011-2014 Mustang GT 5 12-13-2013 02:10 PM
03 5.0 mustang? Doe_Rae_mi 1996-2004 Mustang GT 3 12-02-2011 05:25 PM
07:02 PM
