K&N filter keeps falling off - Mustang Evolution
Old 02-06-2014, 08:23 AM   #1
TorchRed03's Avatar
Region: Nebraska
I've tried securing it many times, tightened it up real good, pushed it in as hard as i could. I keep opening the hood to find that it has fallen off again. I just got an oil change so hopefully it's ok. I only have a little bit of time after school before work and I might get a new clamp, anyone know where I could get one?
2003 Mustang
intake, exhaust, tune
TorchRed03 is offline   Reply With Quote
Old 02-06-2014, 08:39 AM   #2
TorchRed03's Avatar
Region: Nebraska
I think Lowe's has a clamp 4 inches in diameter so I will try that, hope the oil change helped me out
2003 Mustang
Old 02-06-2014, 09:44 AM   #3
yellowconve's Avatar
lowes or home depot even wall mart in the plumbing
yellowconve is offline   Reply With Quote
Old 02-06-2014, 10:00 AM   #4
Getn off's Avatar
Try using isopropyl alcohol to clean the rubber filter inner surface and the mating surface it attatches to. My guess is that it has a bit of oil or grease there and wont bite.
Troy
Getn off is offline   Reply With Quote
Old 02-06-2014, 11:37 AM   #5
TorchRed03's Avatar
Region: Nebraska
Troy
Thanks I will try that, that might be more of the problem
2003 Mustang
Old 02-06-2014, 02:12 PM   #6
Wow what a quwinidense I had that happen to me 2 days ago. I had a buddy of mine who works at an local Exxon tighten it up for me. Not sure of it fell back of yet gonna check later. Does that mess up anything
Old 02-06-2014, 02:26 PM   #7
edross's Avatar
are you sure the filter is all the way on before you tighten? try heating the base of the filter with a blowdryer to soften and you should be able to slide on all the way then tighten
2003 gt, sct custom tuned by VMP, k&n fipk, upr o/r x-pipe, dynomax turbo mufflers, mm c/c plates, mm full length subframe connectors, h&r race springs, bullit rims 18x10 rear 18x9 front, 4.10 gears, 20% tint, 9 inch shorty antenna
edross is offline   Reply With Quote
Old 02-07-2014, 01:55 PM   #8
lemons95's Avatar
I ran a filter over once because it fell off, I didn't realize what happened until I entered the freeway and I heard this whooshing sound.
Old 02-07-2014, 03:04 PM   #9
samuelsmith's Avatar
It's hard to put the factory filter back in. Mine did not connect right a few times
Old 02-07-2014, 04:11 PM   #10
TorchRed03's Avatar
Region: Nebraska
I cleaned the surfaces with the isopropyl alcohol and I think the rubber is sticking together a little better. It has stayed on so far and I have a new clamp from Lowes just in case so it should be good. Always be sure to push it on all the way.
2003 Mustang
Get together date set! schmitty426 The Bar 13066 10-20-2017 05:17 PM
2011 to present oil filter spills bucko General Mustang Discussion 4 01-28-2014 10:35 AM
For Sale: K&N high performance air filter (V6, GT) Fax22 Mustang Parts for Sale and Wanted 2 02-13-2013 04:35 AM
Air filter heatshield alexak187 1996-2004 Mustang GT 0 01-26-2012 07:01 PM
Procal Ford Tuner and K&N filter? dailey 2011-2014 Mustang GT 9 07-15-2011 01:40 PM
» Members Mustangs
My baby
Cinn
my gt
dcox7178
Add your Mustang
11:32 PM
