Overheating :/ - Mustang Evolution
Old 02-09-2014, 10:10 AM   #1
Jaytraeg's Avatar
Overheating :/
Hey guys, having a bit of a problem. So, my car had a crack in the coolant reservoir for a little bit, which made the car overheat every time I drove it (never more than 3 miles at a time from school and back). Well, I replaced the reservoir, filled it with coolant and it's still overheating. It's not losing coolant, either. Any ideas?
Jaytraeg is offline   Reply With Quote
Old 02-09-2014, 10:20 AM   #2
Mosified's Avatar
How many miles does it have? Waterpump maybe? My brothers car overheated once and his intake melted on his 2000 GT :-[
Old 02-09-2014, 03:44 PM   #3
samuelsmith's Avatar
Sometimes leaks tear up old water pumps. Happened to me. I would crank the car and open the radiator cap. Look and make sure water is circulating.
Old 02-09-2014, 03:53 PM   #4
Jaytraeg's Avatar
Yeah, now that I think about it there has been a whirring coming from under the hood... It has about 170000 miles on it.
How do I check if the water is circulating? Sorry for the newbie question.
Old 02-09-2014, 03:58 PM   #5
You will see the water move. If it stays level, the water is not circulating. Put the cap back on if it is level in 20sec try again. Remember to let the car get hot enough for the thermostat to open. Not too hot where you will burn yourself from a pressure eruption. A few mins with the gage 30% away from cold.
Old 02-09-2014, 05:28 PM   #6
Mosified's Avatar
Do you know the last time it was replaced?
Old 02-09-2014, 06:09 PM   #7
Mosified's Avatar
Im guessing because its so cold out you tried turning the heat on? And do you have to burp the system so the water flows properly? Try squeezing the radiator hose to make sure there water in it. The top one..
Old 02-09-2014, 06:36 PM   #8
Jaytraeg's Avatar
Well, the water level does change when I take the cap off, so probably not the pump. And when I turn the heat on, only cold comes out...
Old 02-09-2014, 06:41 PM   #9
Mosified's Avatar
Read this Stang Overheating and Heater not Working
Old 02-11-2014, 04:41 PM   #10
Jaytraeg's Avatar
Awesome. Thanks so much!
Old 02-11-2014, 07:50 PM   #11
Mosified's Avatar
Anytime!!)) good luck
Overheating!! Zinc Pre-2005 V6 Mustang 13 02-05-2014 07:23 PM
slight overheating on hot days hepler02 Pre-2005 V6 Mustang 4 07-03-2013 07:11 PM
overheating problem Anthony8994 Pre-2005 V6 Mustang 14 10-19-2012 08:35 AM
Another Issue (overheating) bradh2414 Pre-2005 V6 Mustang 18 07-27-2011 04:19 PM
Overheating issue Edge4 1979-1995 Mustang GT 11 07-19-2011 10:06 PM
02:28 AM
