Getting 4.10s Question about tuning - Mustang Evolution
Old 02-11-2014, 02:18 PM   #1
TorchRed03's Avatar
Region: Nebraska
I have a 91 race tune from bama so if I swap out 3.27s for 4.10s can I just go on my tuner and switch the ratio on the tuner to 4.10s and I'm good to go? Any need to write a new tune?
2003 Mustang
intake, exhaust, tune
TorchRed03 is offline   Reply With Quote
Old 02-11-2014, 02:26 PM   #2
samuelsmith's Avatar
I only know the stock tire size with 4.10. Some tires are within 2 to make the equivalent to stock tire size. Example: My Cobra 18" rims are equivalent to stock size.Go in the tuner if you have stock tire size and put @810 revs/miles. We did a post in the v-8 section about this I will look for it later. It has very helpful 411.
Have you updated your tuner? You can adjust axel ratio if your tuner is updated.
Old 02-11-2014, 02:44 PM   #3
TorchRed03's Avatar
Region: Nebraska
Originally Posted by samuelsmith View Post
I only know the stock tire size with 4.10. Some tires are within 2 to make the equivalent to stock tire size. Go in the tuner if you have stock tire size and put @810 revs/miles. We did a post in the v-8 section about this I will look for it later. It has very helpful 411.
I last updated it a few months ago, and I'm on 245/45/17s. I see on my tuner I have the option to change the axle ratio and revs/mile
2003 Mustang
Old 02-11-2014, 03:11 PM   #4
Gear install (finally)
Read this post it is helpful.
That is the stock diameter on 99-04. Remember you have a 8.8 so the rim size changes to v-8. 810 rev/miles is the answer.
Old 02-11-2014, 03:25 PM   #5
TorchRed03's Avatar
Region: Nebraska
Is it still @810 if It's the 7.5 t lok I'm going with? Thanks
2003 Mustang
Old 02-11-2014, 03:29 PM   #6
I would call Am and tell them you got the tuner from them and ask for the answer. 4.10s in a 7.5 rear end require a specific gear designed for the 7.5. Make sure you have the right gear. It is hard to find.
Old 02-11-2014, 07:51 PM   #7
Mile high JDF's Avatar
Depending on the tuner you have then yes you can go in and manually change it
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-12-2014, 08:01 AM   #8
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Hey TorchRed,
Yes. You can go into your tuner and change the gear ratio yourself if you'd like. However, that's one of the great benefits of our Free tunes for life program. You can just give the Bama team a call and they'll gladly make this adjustment for you and send out a new tune right away! This should only take a few minutes and your speedometer will be in good shape. We won't change anything else in the tune, just the gear ratio.
I hope this helps. Let me know if you have any further questions or need some assistance. Our Bama Performance tuning specialists are here in the building Monday-Friday from 9AM-5:30PM EST and Saturday 9AM-5:30PM EST. You can hit them up directly at 888.226.9764 and they'll get you squared away!
-Dan
New '14 Owner with lowering question Evil2014GT 2011-2014 Mustang GT 10 04-11-2013 02:46 PM
Tuning and Tires DEvermore 2011-2014 V6 Mustang 7 03-31-2013 12:05 AM
Tuning question??? Benzo 2011-2014 Mustang GT 8 01-25-2012 07:10 AM
Kenne bell 2.6L question Ahmed ali khan 1996-2004 Mustang GT 4 11-14-2011 12:54 PM
Tuning question? 86gt 1979-1995 Mustang GT 7 08-31-2011 01:03 PM
04:33 PM
