Throttle body? - Mustang Evolution
Old 02-11-2014, 07:10 PM   #1
keaton12's Avatar
Throttle body?
Should I buy the 65 mm throttle body with the SR CAI from AM?
keaton12 is offline   Reply With Quote
Old 02-11-2014, 09:31 PM   #2
ProjectTurboV6's Avatar
What do you have done to your car?
ProjectTurboV6 is offline   Reply With Quote
Old 02-11-2014, 10:15 PM   #3
samuelsmith's Avatar
You have to port and polish the upper intake for this to work. o see the first o/0 now look at the second 0. You will need to port the 5mm difference into where the tb connects to the intake. People get 210hp 240 tq without upgrading tbs. compared to the stock 190/210. Add a 10% loss in power due to age of the your motor.
Old 02-11-2014, 10:22 PM   #4
slow281
sixpac's Avatar
Region: Nebraska
Skip.. Spend your money on exhaust.. Or gears.. CAI isn't a bad idea.. But skip the TB
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 02-11-2014, 10:34 PM   #5
keaton12's Avatar
All I have so far is true dual exhaust
Old 02-11-2014, 10:47 PM   #6
You can rip out the rubber tubing that goes into your fender and put a cai air cleaner onto your tube coming out of the throttle body. Save money for a 8.8 gt rear end with 3.73 gears
Old 02-11-2014, 10:47 PM   #7
recommend getting a tb spacer. It added about 200rpms to my factory tune. The tb spacer adds length to the runners. This makes the air travel path longer adding more tq. Do not expect the same results. I have a different intake. But you will see slightly different results for $65.
Old 02-11-2014, 10:48 PM   #8
keaton12's Avatar
How much would the rear and gears cost?
Old 02-11-2014, 11:12 PM   #9
You can find a rear for 100, then the gear kit is like 280. Feels like a complete different car
Old 02-12-2014, 12:25 AM   #10
slow281
sixpac's Avatar
Region: Nebraska
So you bought a 65$ paperweight... 200 RPMS? How does that work? You may see a gain of 1-2 HP TOPS.. And that's if your F/I
2001 GT - True Blue
Old 02-12-2014, 12:58 AM   #11
After a sixpac you will believe me! LOL
The v-8 guys like it too
Throttle body spacer
Old 02-12-2014, 07:11 AM   #12
keaton12's Avatar
What mods should I get? So far I only have dual exhaust
Old 02-12-2014, 09:25 AM   #13
slow281
sixpac's Avatar
Region: Nebraska
After a sixpac you will believe me! LOL The v-8 guys like it too Throttle body spacer
I don't see anyone there who liked it??
2001 GT - True Blue
Old 02-12-2014, 09:26 AM   #14
slow281
sixpac's Avatar
Region: Nebraska
I don't see where they like it?
2001 GT - True Blue
Old 02-19-2014, 08:54 AM   #15
Sluder4's Avatar
If you just have duel exhause then go with a CAI and then a tuner. After those two slap a 8.8 rear end with some 3.73 gears (auto is 4.10 geRs) and you'll be very happy. After that it's the expensive mods lol
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 02-19-2014, 01:53 PM   #16
Notice my mods. I may get a small gain from a throttle body, but it is not required till I hit 400 hp.
Market horse power 101
Let me explain this the best I can.
First you must understand marked horse power.
For example: A v-6 under drive pulley gains 8 market hp.
What they do not explain to you is that they revved the engine the engine to the limit, to figure out the max hp. The daily driver will not rev. there engine to max rpms and jump off every red light and gain 8 hp.The average person will gain 1 hp. Dependent on average rpms.
Understanding perfect conditions at a dyno: The weather will effect your dyno. if perfectly tuned. How many mods a company has added before fixing the weak link, is not explained when you buy the part. I may gain 5 hp from a throttle body. notice the mods I do have. When a company tells you, this product will add 5 hp. they are not required to tell you how many mods they added to make the mod they are selling gain hp. Now you understand the basics of marked hp.
Old 02-20-2014, 01:11 AM   #17
+1000
Throttle body and short throw shifter Mayhem48 General Mustang Discussion 14 01-28-2014 09:22 AM
Throttle body spacer PonyBoy415 General Mustang Discussion 25 01-26-2014 01:18 PM
cleaning throttle body todd mulder 2005-2010 Mustang GT 22 09-01-2012 06:01 PM
Throttle Body? 2011CS 2011-2014 Mustang GT 2 11-14-2011 06:28 AM
Throttle Body Spacers jbanks 1996-2004 Mustang GT 5 07-11-2011 08:43 PM
07:33 PM
