4.2/3.8 interchange parts - Mustang Evolution
Old 02-11-2014, 08:28 PM   #1
mummert_96v6's Avatar
I was wondering do the 3.8 and 4.2 use the same pistons or rods? I know they use the same block and different crank shafts but I'm not sure if the rods or pistons are the same. Can someone clear this up for me?
mummert_96v6 is offline   Reply With Quote
Old 02-11-2014, 08:53 PM   #2
samuelsmith's Avatar
rods, pistons, and crank are different
Old 02-11-2014, 09:31 PM   #3
ProjectTurboV6's Avatar
Cam is different too! The only difference is the longer stroke
ProjectTurboV6 is offline   Reply With Quote
Old 02-11-2014, 10:12 PM   #4
You will gain 15hp and 45 tq if you use the right intake
Old 02-11-2014, 10:24 PM   #5
slow281
sixpac's Avatar
Region: Nebraska
What?
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 02-11-2014, 10:30 PM   #6
Originally Posted by sixpac View Post
What?
Yea!
Old 02-11-2014, 10:33 PM   #7
The 98 has 210hp I have that intake ported and polished with an 03 windstar upper.
Old 02-12-2014, 12:30 PM   #8
http://www.musclemustangfastfords.co...stroker_build/
This article says that the two motors use the same connecting rods though
Old 02-12-2014, 01:16 PM   #9
Originally Posted by mummert_96v6 View Post
V6 Stroker Build - Muscle Mustangs & Fast Fords
Connecting Rod Lengths - V6Power Messageboard
You are right. The top article messed me up a while ago. Taylor corrects every ones mistakes. Good catch mummert.
98 3.8 stroked to 4.2 - V6Power Messageboard
You can put larger rods in it. SSMS has the right size 351 rods.
Old 02-12-2014, 06:35 PM   #10
So does anyone know if the supercoupes use the same length rod as a normal 3.8/4.2?
Old 02-14-2014, 11:05 PM   #11
I finally read this article all the way through. Good 411. I was thinking about a stroker, getting some pi heads next month and the 3.8 gains are not big. Great to know you can use the F-150 harmonic balancer and flywheel.
"Ofria sanded on both ends of the connecting rods to equalize their weights".
I know the flywheel, crank pulley, and crank are effect by internally and externally balanced engines. I have a feeling the rods are effected too. I have never worked at a machine shop and can not say 100% sure either way.
I would recommend bringing the rods to a machine shop or ordering new ones.
Read more: V6 Stroker Build - Muscle Mustangs & Fast Fords
Old 02-14-2014, 11:13 PM   #12
bump for answers
Old 02-15-2014, 02:32 PM   #13
lemons95's Avatar
The camshaft is different, it still interchanges though. I used it in mine since I read it was better than the 3.8 can.
Old 02-16-2014, 12:45 PM   #14
You gain 5 hp and 15 tq putting it in a 3.8 right?
Old 02-16-2014, 03:49 PM   #15
lemons95's Avatar
I think its less. I don't think anyone's taking these cams to the dyno to verify.
Old 02-16-2014, 10:32 PM   #16
97-04 4.2L
185/194 .443/.445 112LCA 110ICL
99-03 3.8L XR3Z-6250-CA
178/194 .427/.446 116LCA 111ICL
Some one reported it from another sight. I do not remember who. The same guy tried to speck his cam and was way off. I do see minor gains on the intake side. But not sure exactly how much. Like you said Lemons its not worth dynoing.
Either way I would not put a factory cam in a 4.2. A comp cam either way.
204/216 .480/.480 115LCA 108ICL 259HR115 44-701-9 89-PRESENT
If you want hight tq numbers. This cam will work without rockers, but needs big springs.
or a
207/215 .500/.500 109-112 LSA
IF YOU WANT HIGH HP NUMBERS.
With bv heads I would say 60 hp
Old 02-19-2014, 07:23 PM   #17
davidcseifert's Avatar
Region: Arkansas
Stock 4.2 cam is only slightly more aggressive worth a few hp and the lsa change makes the idle a little more "lumpy"
blower/new cam soon
For Sale: Ford Parts Jackal43x Mustang Parts for Sale and Wanted 56 05-21-2014 09:27 PM
For Sale: Assorted '12 GT Parts Jackal43x Mustang Parts for Sale and Wanted 20 06-20-2013 08:47 PM
damn truckers. need front bumper help R6man 1996-2004 Mustang GT 25 05-24-2013 10:41 AM
For Sale: For sale 05 to 09 Mustang GT oem parts Luna1994 Mustang Parts for Sale and Wanted 13 05-18-2013 02:07 PM
need parts wnt2gofst 2011-2014 Mustang GT 4 09-14-2011 09:36 AM
11:23 PM
