Burning smell - Mustang Evolution
Old 02-13-2014, 04:35 PM   #1
Burning smell
So everyone I turn my ac on it smells like something is burning and I just turn it off. Anyone have any ideas
Old 02-13-2014, 09:54 PM   #2
The only thing electrical that turns on, inside of the car when the air conditioning is turned on, is the blower fan.
Do you experience this smell when you turn on the heater? The defroster?
Post a vid.
Smellevision...
Old 02-13-2014, 10:01 PM   #3
Post a vid.
Smellevision...
No I don't think so since I put the heater on low for like 10 minutes. It used to throw cold air now it's like a mix between hot and cold I don't leave it on because the smell scares me
Old 02-13-2014, 10:03 PM   #4
Could it be antifreeze that you're smelling?
Old 02-14-2014, 08:20 AM   #5
Mustang81596's Avatar
Is your thermostat working correctly? The absolute worst thing that could send out a burning sent would be your heater core
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 02-14-2014, 10:08 AM   #6
I think it is because the car doesn't overheat
No it just smells real bad. Idk if you have ever used a vacuum and the belt goes bad and it starts heating up.... Well that's the smell
Old 02-14-2014, 11:38 AM   #7
Oh yes! I know what that smells like..
Turn on the air with the hood opened and make sure that the compressor is not frozen up when the air conditioning compressor clutch is engaged.
Old 02-14-2014, 03:48 PM   #8
I'll look into it. Could no freon cause this symptom
Old 02-14-2014, 03:59 PM   #9
There is a pressure switch in the system that prevents the a/c clutch from engaging if the pressure is too low from not having enough Freon.
Old 02-14-2014, 04:55 PM   #10
Clutch? Or is it called compressor cause that thing won't move when ac gets turned on
Old 02-14-2014, 06:01 PM   #11
The pulley on the a/c compressor should spin freely, if you were to take the belt off.
Inside of that pulley is a magnetic clutch that engages the a/c compressor when you turn the hvac control inside of the car to a/c.
If your compressor is seized up for some reason, the a/c pulley will STOP and the belt will just slide over that pulley whenever the a/c OR the defrost is turned on.
That could be the smell that you're experiencing.
I would expect it to squeal as well, but it's something to look at...
Old 02-14-2014, 06:53 PM   #12
It does squeak on start up and I thought that was strange since the belt is new. Didn't make any noise when I popped the hood though. I'll see how much a mechanic will charge and if it's too much it will be a fun diy experiment.
gas fume smell winkawak 2011-2014 Mustang GT 10 11-13-2013 09:16 AM
I picked up an extra 35 horsepower today ronnie948 2011-2014 V6 Mustang 51 06-13-2013 05:32 AM
Weird smell at high rpms? Mweigt07 2011-2014 Mustang GT 35 01-05-2012 02:38 PM
burning smell GTKidd53 General Car Discussion 9 01-01-2012 09:45 AM
Burning smell? 98projectpony Pre-2005 V6 Mustang 4 12-09-2011 06:59 PM
11:44 PM
