GT to V6 - Mustang Evolution
Old 02-14-2014, 01:21 PM   #1
Blakhwk's Avatar
GT to V6
Two questions please.
will the GT cats and h pipe bolt directly to the V6?
will the GT auto transmission fit on the V6 directly?
both for 99-04.
Thanks
Blakhwk is offline   Reply With Quote
Old 02-14-2014, 02:00 PM   #2
lemons95's Avatar
99-04 gt transmission won't work. A 94-95 gt will work though. The v6 uses the ford smallblock bolt pattern. Which the gt ditched in 96 when it started using the modular 4.6
Old 02-14-2014, 02:17 PM   #3
Looks like your second question was answered... As for the cats, not entirely sure.. But the V6 and GT both use a 2.25" diameter piping.
Old 02-14-2014, 02:41 PM   #4
Blakhwk's Avatar
good to know that, thanks man.
Old 02-14-2014, 02:45 PM   #5
Blakhwk's Avatar
the other day i saw on graigslist a gt cats and h-pipe that has couple of hundred miles on it for $100 bucks, so i thought maybe it will fit.
Thanks though.
Old 02-14-2014, 03:01 PM   #6
Adogg's Avatar
^^ it's a wast of time and money, why would you wanna take off your stock cats and mid pipe just to put on stock cats and mid pipe from a gt?
Don't hate....... appreciate
Old 02-14-2014, 10:22 PM   #7
Blakhwk's Avatar
i want to go for true dual, so i thought this is going to be a cheap way to do it, i already have a gt catback and i need to get the h pipe now.
Old 02-14-2014, 10:54 PM   #8
samuelsmith's Avatar
The Gts have 2 cats instead of 4.
Old 02-14-2014, 10:55 PM   #9
Pretty sure my 01 4.6 had 4 cats,
Old 02-14-2014, 11:09 PM   #10
I was looking at a performance exhaust system in my uncles shop. You are probably right.
Old 02-15-2014, 12:23 AM   #11
Most aftermarkets will come with 2 high flows.... Stockers is 4
Old 02-15-2014, 07:18 AM   #12
Blakhwk's Avatar
Correct they are 4.
Visca Barça
Old 02-15-2014, 07:21 AM   #13
Blakhwk's Avatar
But I'm still not sure if it has the same length and fitment to the v6 manifolds, that's why I didn't buy it, looks a good deal though.
Visca Barça
Old 02-17-2014, 10:10 PM   #14
austinknoll's Avatar
They won't bolt right up but a little fabrication from an exhaust shop would make them bolt right up
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 02-17-2014, 11:14 PM   #15
GT to V6
CoolHorsey is offline   Reply With Quote
Old 02-17-2014, 11:40 PM   #16
Originally Posted by CoolHorsey View Post
My GT has two. I have no idea if they are high flows though Attachment 148091
Sent from my Barbie Dream Phone®
Those look stock..... And don't forget the other side lol. 2+2=4
Old 02-17-2014, 11:49 PM   #17
GT to V6
It's one on each side though I think
Do you have a pic of yours with the 4 to compare?
Old 02-18-2014, 06:56 AM   #18
lemons95's Avatar
You should have two more, can't see them from under the car though. They right below the exhaust manifolds, you can see them if you pop the hood.
Old 02-18-2014, 07:46 AM   #19
There's nothing from those cat backwards. It goes straight to my mufflers
Old 02-18-2014, 09:12 AM   #20
Adogg's Avatar
Name:	ImageUploadedByMustang Evolution1392739757.433231.jpg
Here is what it is supposed to look like man, if they are not there then previous owner could have removed them. If so look for welding marks. Oooo and btw that is a 94 gt mid pipe but yours should look some what like that maybe not as beat up.
Old 02-18-2014, 09:59 AM   #21
GT to V6
Nah mine only has two thanClick image for larger version
Old 02-18-2014, 10:03 AM   #22
Adogg's Avatar
Yea by the looks of it they have been removed, do you have a cel? Did your car come with a hand held tuner?
Old 02-18-2014, 10:05 AM   #23
No I bought the car untuned and it had no CEL. But I have since bought a tuner
Old 02-18-2014, 10:18 AM   #24
Adogg's Avatar
Hmmm, well I would assume having a set of cats removed from the car would cause a cel. Unless the previous owner got mil eliminators. But I'm not 100% sure with your year car
Old 02-18-2014, 11:03 AM   #25
Yeah but as long as it runs good I don't mind. 2 cats are better than 4/6 LOL!! I don't think 2 cats are robbing me if much Hp tbh
Plus I can't even get an offroad mid pipe bc the catback and midpipe are welded together lol
So Imma just leave it as is
Old 02-18-2014, 11:07 AM   #26
Adogg's Avatar
Yea for sure leave it as is man, if anything the less cats your gaining power. I would tell bama next time you get a new tune that your running two less cats then stock and you might be able to get more power out of her.
Old 02-18-2014, 11:11 AM   #27
Hmmm that's a good idea. I just wish I could could get long tubes and keep the 2 cats I have.
I got my car at auction with no paperwork and the previous did owner did the exhaust.
He really made my car a PITA
Old 02-18-2014, 11:13 AM   #28
Adogg's Avatar
If you really want long tubes look for a shorty catted mid pipe with high flow cats. I think they make something like that. And just junk everything that under there now.
Old 02-18-2014, 11:16 AM   #29
Adogg's Avatar
http://www.americanmuscle.com/bbk-hp...tted-9604.html
Like this one!! Very expensive but it will work mint
Old 02-18-2014, 11:16 AM   #30
Screaming Mach's Avatar
Is this your exhaust? Because mine looks the same
Screaming Mach is offline   Reply With Quote
Old 02-18-2014, 01:43 PM   #31
Yeah that's mine right there
---------- Post added at 08:43 PM ---------- Previous post was at 08:42 PM ----------
It's just such a pain in the butt Imma leave it as is lolol
Old 02-18-2014, 08:28 PM   #32
Blakhwk's Avatar
Thanks dude, I'll check how much it will cost at local shops.
Visca Barça
Old 02-19-2014, 04:31 AM   #33
lemons95's Avatar
From the looks of your picture I can see four. I there up closer to the engine... Not the mufflers. They have a little bend to them kinda... you have all 4.
Old 02-19-2014, 07:32 AM   #34
Adogg's Avatar
^^ **** he is right I just looked at the first pic you sent and no I see them. Sorry for the confusion
V6 to GT bumper install help NicholasP 2005-2010 V6 Mustang 1 01-18-2014 09:49 AM
I might be leaving the V6 thread for the GT... dobypaw3 2011-2014 V6 Mustang 11 10-17-2012 04:48 PM
Subwoofers V6 or GT Delta vt 2011-2014 Mustang GT 7 01-01-2012 11:56 AM
Gt midpipe on v6 Dgerow12 Pre-2005 V6 Mustang 3 10-04-2011 11:58 AM
Which should i get for my first Mustang V6 or GT 2012? Dogpatch16 General Mustang Discussion 30 08-12-2011 09:27 AM
06:33 AM
