Throw out bearing squeak after replacement - Mustang Evolution
Old 02-17-2014, 04:24 PM   #1
austinknoll's Avatar
Just like the title says it still squeaks just a little but enough to hear it. I took it to my mechanic to get the entire clutch changed out due to throw out bearing squeal and worn clutch. Just a couple days ago it started squeaking again but not as loud. What could be the problem?
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 02-17-2014, 04:55 PM   #2
TaylorF25's Avatar
I'm thinking that maybe he didn't use enough grease when installing the bearing? Just my first thought
TaylorF25 is offline   Reply With Quote
Old 02-17-2014, 05:19 PM   #3
Screaming Mach's Avatar
Mine did the same thing for about a week or two, and then it quit, all good now bin over a year.
Screaming Mach is offline   Reply With Quote
Old 02-17-2014, 06:43 PM   #4
WJBertrand's Avatar
When does it squeak? Does it do with your foot on or off the clutch pedal?
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 02-17-2014, 07:20 PM   #5
When the clutch is engaged it squeaks but when I depress the pedal it stops
65 Mustang coupe
Old 02-17-2014, 07:27 PM   #6
samuelsmith's Avatar
Have you tried putting penetrating oil on the petal.
Old 02-17-2014, 10:51 PM   #7
WJBertrand's Avatar
Sounds like the t-o bearing is not being completely disengaged from the pressure plate and is instead lightly dragging on it, causing the squeaking noise. I don't know if
There's an adjustment for this or not, but that's how I've fixed this issue on other cars.
-Jeff-
STOC 025
-Jeff-
Ventura, CA
Old 02-17-2014, 11:12 PM   #8
It is still under warranty but I'm kinda pissed. Could it be a worn sleeve that goods over the input shaft? Or should I get an adjustable firewall quadrant?
65 Mustang coupe
Old 02-18-2014, 01:28 AM   #9
Rascal's Avatar
there junk!! I've replaced mine 3 times in the last 5 years. the last time i had it apart i put the Heavy duty ford racing ToB and it doesnt make a noise. the other two bearing, one came from a kit i bought at advance. the other bearing was just a replacement from autozone and both of them chirped like a bird till i replaced them. i have a triple hook quadrant , adjustable cable, and a firewall adjuster and i couldn't ever get it to go away.
Rascal is offline   Reply With Quote
Old 02-18-2014, 02:32 PM   #10
Really? Mine is under warranty from the mechanic but should I go get a ford racing throw out bearing for them to install?
65 Mustang coupe
throw out bearing TXstang125 General Mustang Discussion 6 09-07-2013 10:18 PM
throw out bearing 02StangGT 1996-2004 Mustang GT 25 03-02-2013 10:47 AM
Throw out bearing Mathew r Wright 1996-2004 Mustang GT 2 11-21-2012 07:20 AM
Throw out bearing question jhagan1980 1979-1995 Mustang GT 30 11-27-2011 04:50 PM
Throw Out Bearing? USAF_stang 1996-2004 Mustang GT 9 07-20-2011 02:07 PM
01:49 PM
