Nitrous on 3.9 100 shot, will it be ok - Mustang Evolution
Old 02-18-2014, 01:01 PM   #1
crashjames's Avatar
Ive seen alot of people with GT say they run 100 shot of nitrous for many years with no problems. Just wondering if 100 shot would be safe on 3.9 I bought the Nitrous Express kit and got the digital window timer to be extra safe so no running in to low or way to high rpms. every other nitrous install ive done has been on built motors so no worries just curious about doing on stock internals on v6. Also i am using a Dry kit didnt want to mess with the wet setup. Had a turbo setup in mind but would rather do motor swap before put 3 grand in a v6, for 3 grand i could have a hell of motor swap lol
Current Mods: just bought car few months back so list not to large yet lol
STD Lowering springs
Slotted rottors
H-pipe true duals
cold air intake
b&m ratchet shifter (absolutely coolest thing for a auto)
SVT programmer
MSD coil
Smoked headlights
Tinted Tail lights
Sequential tail lights
crashjames is offline   Reply With Quote
Old 02-18-2014, 01:57 PM   #2
2000stanguy's Avatar
How many miles are on your car?
Performance Red 2000 v6- m112 supercharger,42lb green top injectors, 310lph fuel pump, BBK shorty headers, True dual exhaust, strut tower brace, GT rear sway bar, Steeda triax short throw shifter, SR lowering springs, tinted headlights and foglights, polk audio speakers, MTX subwoofer, Kenwood head unit and black leather interior.
2000stanguy is offline   Reply With Quote
Old 02-18-2014, 02:18 PM   #3
JimmyMosqueda's Avatar
100 shot should be fine as long as your engine isn't a high milage one. To be safe I'd run a little less.
Sent from my Pager
JimmyMosqueda is offline   Reply With Quote
Old 02-18-2014, 03:23 PM   #4
Ish416's Avatar
I very much doubt the stock fuel system is capable of adding the necessary fuel to maintain the AF ratio from a 100 shot.
Typically dry systems are good for a 25-50 shot. Wet systems are good for up to 200 and anything more than that needs direct port.
A dry 100 shot will result in your engine being toast. I wouldn't even chance it with a 50 shot.
Do it once, do it right. If you want to spray a big shot, go with a wet kit.
Old 02-18-2014, 03:54 PM   #5
crashjames's Avatar
car has 150k on it. ive had a 50 shot on a stock 4 cyl when i was a kid and had no problems. my car has fuel pressure reg so can up fuel a little to help out. ive seen more then a dozen forums where people are running a 100 with no issues
Old 02-18-2014, 03:56 PM   #6
You can up the fuel pressure with the regulator... But that doesn't mean your injectors and pump will be able to supply that fuel.
Old 02-18-2014, 03:59 PM   #7
I have seen over 100 shot on a v6 before but that was a wet kit. I haven't seen many people run a dry kit on a v6. I would get a dyno tune and run a 50-75 shot. That's too high of mileage to run anymore IMO.
Sent
Old 02-18-2014, 04:04 PM   #8
crashjames's Avatar
i know, i have a set of 40lb injectors on the shelf
Old 02-18-2014, 04:06 PM   #9
crashjames's Avatar
Sent
This kit has jets from 35-150. Honestly i was going to start at the 35 and play with programmer and work my way up. i wanting to do v8 swap next summer. so if i go to far at least i got replacement for it lol
Old 02-19-2014, 07:19 PM   #10
davidcseifert's Avatar
Region: Arkansas
Wet kits do not interfere with injectors, it's completely pump dependent. 100 shot will be perfectly fine with a good tune on the car.. A friend of mine runs a 125 shot on his HCI V6 on a stock bottom end without problems.
blower/new cam soon
Old 02-19-2014, 08:24 PM   #11
crashjames's Avatar
After looking into it more I will more then likely go with the wet kit. What's best way tune for it, do I have to have dyno tune or will hand held tuner work
Old 02-19-2014, 09:01 PM   #12
Region: Arkansas
My tuner, Luis, can set you up with a great nitrous tune through data logging and email. Same way he tuned my built car.
blower/new cam soon
Old 02-21-2014, 01:44 AM   #13
crashjames's Avatar
I have a SCT tuner, would it work on that?
Old 02-21-2014, 10:26 AM   #14
Region: Arkansas
Yes he can just send you tunes to download to the handheld since you already have one.
blower/new cam soon
nitrous
Running a bigger shot of nitrous / NITROUS GUYS Jsmorley81 2011-2014 Mustang GT 5 02-14-2014 01:31 PM
Just got nitrous got a couple Q's! Butsweat 2011-2014 V6 Mustang 33 01-29-2014 11:12 AM
Thinking about NOS. Concerns/Questions.. tgmeyer 2011-2014 V6 Mustang 39 10-23-2013 07:20 AM
nitrous on a v6 245ciPony 2005-2010 V6 Mustang 25 07-10-2012 08:24 PM
08:03 AM
