2002 3.8l Swapped into 1992 240sx??? - Mustang Evolution
Old 02-18-2014, 11:00 PM   #1
What do you guys think? Ok, I'm new here. My name is Dillon. lol. Well, I got bored one weekend and with some really nice customers received a 2002 Mustang for 200$.. I recently blew my Ka24e that i turbocharged in my 1992 Nissan 240sx Coupe. Lets just say for the record I got really really bored....Click image for larger version
Name:	Coupe Shell.jpg
Name:	Coupe Running.jpg
Name:	Coupe Shell Engine In.jpg
Name:	Coupe Shell 2.jpg
Please no haters... All work was done by me.
Now for my problems... just imagine the mustang when thinking about this because i used all wiring from the mustang all the way to the speedometer fuel pump P.A.T.S system... yea the That pesky security thing... thats my problem. I want to get rid of that system and dont know where to begin. Could i build a MegaSquirt ecu and just cut all the garbage wires out? Im used to building older vehicles such as the front engine rear wheel drive Sandrail. Please help!!!
Name:	Dilon Sandrail Drift.jpg
1camslamm3r is offline   Reply With Quote
Old 02-19-2014, 08:18 AM   #2
sam62893's Avatar
That's pretty sick. I love it! Well samuelsmith on here knows all about PATS you could send him a message. Or you could get someone to disable PATS with a tune. How did you go about installing the drivetrain?!? Oh and welcome
Old 02-19-2014, 08:37 AM   #3
samuelsmith's Avatar
Here is the most I got out of the dealership. PATS for dummies translation
Great work on the transformation!
I turned mine off with a tune because I did not have a second key to diagnose.
Pats communicates with the engine, pats box, computer, gage cluster, and key. If you do not include any of these items in your install, pats will cut off your fuel pump. If you rewire the fuel pump you can eliminate the pats system.
Old 02-19-2014, 07:15 PM   #4
davidcseifert's Avatar
Region: Arkansas
There must be something from the mustang you forgot to transfer if you had an entire donor car for the swap. If all is present then something pats related was damaged at one point.
blower/new cam soon
Old 02-19-2014, 08:01 PM   #5
Thanks! and for the drivetrain I cut the crossmember out of both cars and welded Alot of parts together lol hard to explain because it was alot of work but well worth it!
So a megasquirt ECU would allow me to remove all features and run just my motor and tune... just going off of what your tune did.
I am a certified mechanic with many years experience between me and my pops . We hit all the basics and i was driving and street sliding my car. and some of this. street sliding with the girlfriend ended in disaster. took out a 4'' wide aluminium Do not enter, Wrong way sign... my front support held up great just not my fiberglass fenders and headlight. Now i have this problem and got all my piping for my 70 trim turbo off to the side a little bit, And possibly a gtp supercharger in the center. also i have a 4.2l out of a 2003? f150 sitting under my bench in my shop which i planned to do the conversion.
Old 02-19-2014, 08:26 PM   #6
what it used to be , But shall rise again but a little ford flavor too!
ID:	148277   Click image for larger version
Old 02-20-2014, 01:46 PM   #7
I do not know the megasquirt ECU and not brave enough to tune my own vehicle. If I get a chance to take a course in engine dynamics the situation will change.
The way it was explained to me is, "a cell needs to be turned off". I was not told the exact cell. If you can not figure it out I have two recommendations.
One: American Muscle has a Bama tune team that specifically tunes Mustangs. The call is free.
Two: David does not get on here often, but he is subcontracted through Orbits. Orbits sells tunes. He is working on a merger. He may know. David turned pats off when he installed a Cobra gage cluster.
Old 02-20-2014, 01:49 PM   #8
Region: Arkansas
I'm not aware of what needs to be turned off in the tune for it, just know that Luis turned mine off when I requested it.
blower/new cam soon
Old 02-20-2014, 01:58 PM   #9
sam62893's Avatar
Lol orbits? You mean Ortiz?
Old 02-20-2014, 08:36 PM   #10
baddbradd's Avatar
I like it!..why not...
2001 coupe
baddbradd is offline   Reply With Quote
Old 03-04-2014, 05:06 AM   #11
Thanks me too!! cant beat getting about 1000 lbs knocked off without touching the car...
Old 03-04-2014, 07:49 AM   #12
baddbradd's Avatar
You hve too much fun when you get bored...
2001 coupe
03:14 PM
