7.5 to 8.8 rear end swap - Mustang Evolution
Old 02-20-2014, 10:01 PM   #1
sebasflorez's Avatar
Hi guys. I'm planning on buying an 8.8 rear soon, the guy wants $40 for it, 124k miles on it. I was wondering, the rear end is off a 99 GT, I have an 02 V6, any differences in gear ratios? And anyone have a write up on how to do the swap? Thanks!
sebasflorez is offline   Reply With Quote
Old 02-20-2014, 11:23 PM   #2
Both will have a 3.27 gear ratio.
Old 02-21-2014, 01:31 AM   #3
davidcseifert's Avatar
Region: Arkansas
$40? Seems legit.. Bring a tool set and open it up before you buy it, sounds shady as hell to me.
Swap in is simple, 6 bolts hold in the entire rear end (LCA, UCA, and shock bolts). Remove the calipers from their brackets and undo the driveshaft bolts from pinion flange, it's all a direct transfer to the 8.8 so you could say it's pretty much like putting your 7.5 back in.
blower/new cam soon
Old 02-21-2014, 11:25 AM   #4
sam62893's Avatar
$40?!?! That's chump change. 8.8'a are $200+ here. I agree with David. Check it out before you buy it and make sure it's an 8.8
Old 02-21-2014, 12:28 PM   #5
Can't do it anyways, he sold it already, he parts out wrecked mustangs, i'm guessing that's why it was so cheap. Right now i'm trying to get ahold of a guy selling his GT with a blown engine for $400, hopefully i can talk to him soon before that one's gone too.
Old 02-21-2014, 01:22 PM   #6
Where are you finding these parts so cheap. 8.8 around here are 350-500 and that people that parts them out. And GTs with blown motors are $2000+
K.Ledford is offline   Reply With Quote
Old 02-21-2014, 02:44 PM   #7
lemons95's Avatar
I paid $280 for a wrecked gt with a running engine.
Old 02-21-2014, 02:58 PM   #8
It's Louisiana man, not much appreciation for Mustangs down here
Old 02-21-2014, 05:36 PM   #9
samuelsmith's Avatar
You will need 4 jack stands and a big jack. Or 2 jack stands, spring compressor, and a decent jack. 1 ton + hydraulic jack.
If you have a lift you will only need 2 pipe jacks and a transmission jack.
To get the drive shaft bolts off you will need a 12 point socket. Probably a 12 or 13 half inch size. You will also need a impact, breaker bar, or wrench with a pipe. Not sure what size the last 4 bolts are.
Remember to remove the calipers and do not let them hang.
Old 02-21-2014, 05:37 PM   #10
mummert_96v6's Avatar
Lol I got my 8.8 out of a '00 gt with 70xxx on it for $100 and it was delivered
mummert_96v6 is offline   Reply With Quote
Old 02-21-2014, 05:39 PM   #11
Why do you need all that stuff? I jacked the back of my car up put the back on stands. Took the shocks loose and the springs came out simple then it was pretty simple the rest of the way
Mustang 2 motor swap. Curtiswhitehead 2.3 Mustang 2 07-10-2013 09:06 AM
1996 mustang GT rear end gear change soldierdude28 1996-2004 Mustang GT 6 08-24-2011 04:15 PM
Rear end advice t0t4lbl4ck0ut 1996-2004 Mustang GT 6 08-07-2011 07:59 PM
Rear end in 1994 mustang V6 kevin Grove General Mustang Discussion 4 07-16-2011 07:14 PM
05:55 PM
