Correct speedometer gear... - Mustang Evolution
Old 07-29-2008, 05:34 PM   #1
67mustang97's Avatar
Region: Vermont
I have a 97' 3.8 with 4.10's and 275/45/17 in the rear. My speedometer is about 20 mph off. I was told that I could correct the the speedometer with a new gear. Does anybody know what color gear I need to get my speedo back to within reason? Does this gear go in the tranny or in the gauge cluster?
Old 07-30-2008, 11:10 AM   #2
Scut95's Avatar
Re: Correct speedometer gear...
is your car a 5 speed or automatic?
Old 07-30-2008, 11:33 AM   #3
1234's Avatar
If its a manual it goes in the tranny. I pretty sure its red.
Old 07-30-2008, 01:11 PM   #4
Region: Vermont
My car is a 5 speed.
Old 07-30-2008, 01:33 PM   #5
Herbstang's Avatar
Check this link out Speedometer Recalibration Gears - '79-'98 Ford Mustang
Old 07-30-2008, 01:46 PM   #6
use the red one , you can get it from your local ford dealership for about 10$ and it shouldnt take more then 15 - 20 minutes to swap out.
Benjytps is offline   Reply With Quote
Old 07-31-2008, 10:01 AM   #7
you cant get it 100% accurate with just a speedo gear, you have to swap the one on the transmission as well. The other option is a dallas speedcal unit.
Old 08-13-2008, 03:17 PM   #8
Region: Vermont
Steeda says use the white gear, So I put one in and my speedo is still about 7 mph off. Way better than the stock yellow gear but I was under the impression it would be a bit closer. Is there any way to get a more precise reading? I used a tune on my 02 GT to correct my speedo, will a tune help a 97 or will I just have to live with it?
Old 08-13-2008, 03:20 PM   #9
1234's Avatar
try the red gear. And a tune wont help it. it mechanical not electric.
bush finally comes correct... dark The Bar 9 08-27-2004 12:39 PM
auto/manual tranny gear and rear gear STOCK ratios SpectorV Pre-2005 V6 Mustang 0 07-08-2004 02:41 PM
chip correct Falcon Pre-2005 V6 Mustang 19 01-04-2004 03:34 AM
The Correct Computer Chip Donny B Pre-2005 V6 Mustang 1 11-21-2003 07:13 PM
08:29 AM
