Another t56 swap question - Mustang Evolution
Old 02-25-2014, 01:33 AM   #1
Okay, so i've been looking around, and cant seem to find a clear answer on this. I'm looking to swap a t56 transmission into my 95 v6 mustang. from what i gather, there is now bellhousing that would allow you to swap this into the gt 5.0. but from what i understand the gt and the v6 both use the t5 transmission with the same bellhousing. (or at least the same bolt pattern...i think the starter is a little different or something?) if it works for the 5.0 shouldn't it work for the v6 as well. or can someone explain why it wont work, or what the starter issue is.
Or, will it be possible to put the GT flywheel and clutch in to fix the starter problem?
Here's the bellhousing i found.
http://www.summitracing.com/parts/qt...FZTm7Aod9WQAhQ
jmoon4 is offline   Reply With Quote
T56 Swap question jmoon4 Pre-2005 V6 Mustang 0 02-23-2014 12:36 AM
My official 5.0 engine swap thread PureVenom 1979-1995 Mustang GT 35 10-06-2013 12:12 PM
302 to 351 swap 88fox 1979-1995 Mustang GT 23 01-23-2012 08:31 AM
Ecu question Silversky545 1996-2004 Mustang GT 9 01-22-2012 01:26 AM
? On 5 Lug Swap SleepingStang 1979-1995 Mustang GT 8 01-05-2012 09:16 AM
11:31 PM
