Best year for 4.2 swap? - Mustang Evolution
Old 02-25-2014, 05:33 PM   #1
mummert_96v6's Avatar
Alright I just got my truck on the road and the stangs build can finally begin. What would be the best year f150 to get a 4.2 motor out of to swap into my 96? I'm keeping the single port setup and a friend is gonna build me a custom intake and port my heads.
mummert_96v6 is offline   Reply With Quote
Old 02-25-2014, 10:00 PM   #2
lemons95's Avatar
I think it's 99 or newer? They made them all the way up to 2008, so it should be pretty easy to find one.
Old 02-25-2014, 11:38 PM   #3
davidcseifert's Avatar
Region: Arkansas
They're all the same, just find one with low miles. Custom intake setup like? Don't put a boxed upper unless boosted! Throw in a cam while you're at it though
blower/new cam soon
Old 02-26-2014, 02:17 AM   #4
lemons95's Avatar
I thought the early 4.2 had a different stud girdle that hits the 3.8 oil pan?
Old 02-26-2014, 07:38 AM   #5
He's making me an intake similar to the stock manifold but were just gonna make it out of box tubing because te stock are such a pain to port. It's pretty much gonna be like an edlebrock intake but for a v6 and using a GT TB. And yea I on buying a regrind from you David
Old 02-26-2014, 01:48 PM   #6
Region: Arkansas
Long as you use 01-04 3.8 pan there are no clearance issues.
So basically a short runner style of a stock intake?
Sounds good!
blower/new cam soon
Old 02-26-2014, 02:29 PM   #7
samuelsmith's Avatar
That 6 shooter dude was wrong. You can just put 4.2 rods, pistons, and crank in your 3.8. I e-mailed a guy who makes 4.3s out of 3.8s
Old 02-26-2014, 08:48 PM   #8
I thought the bore was different??
Old 02-26-2014, 09:30 PM   #9
My e-mail said the bore is the same. I double checked it comparing Autozone piston rings for the 4.2 and 3.8. If you add 25,50, or 75 mm it would be the same add on either engine.
Old 02-26-2014, 09:32 PM   #10
lemons95's Avatar
Same bore, because they have the same block. Just different crank and connecting rods, also the balancing equipment.
Old 02-26-2014, 11:54 PM   #11
Region: Arkansas
Rods are the same for 3.8 & 4.2, pistons and crank are not.
blower/new cam soon
Old 02-27-2014, 12:20 AM   #12
lemons95's Avatar
Close enough.
Old 02-27-2014, 08:07 AM   #13
The rods are the same and the bore is the same apperently just where the wrist pin is asin off center in the piston is different
My official 5.0 engine swap thread PureVenom 1979-1995 Mustang GT 35 10-06-2013 12:12 PM
4.6 to 5.4 Swap Topless04GT 1996-2004 Mustang GT 44 12-28-2012 08:05 PM
5.4 swap? MustangGT02 1996-2004 Mustang GT 8 05-16-2012 07:17 PM
01 mustang v6 swap to 01 4.6 gt 99redbeast General Mustang Discussion 1 02-12-2012 09:50 PM
Engine swap question!! Tominkc 1996-2004 Mustang GT 1 02-09-2012 12:15 AM
02:58 PM
