07-15-2003, 11:10 PM
#1 | | Registered User
autolite app-764
mfracing is ready to rumble!
07-16-2003, 01:51 AM
#2 | | Registered User
| Re: NX 100 Shot Quote: |
Originally Posted by erick Instead of getting a Procharger, ive decided to go with a 100 shot of nitrous. However, after doing searches here and on 3.8, i've been unable to come up with a straight answer on what I need to safely run a 100 shot. Will I need to upgrade the fuel system? What about a larger Maf? Will I need to get forged internals? Also, if i get forged internals will i be able to safely run a 150 shot? | the time and labor will be a lot to start building your engine up. pistons get "ported"  at about 125 shot or so. don't bother with that now, firs tlearn more about your car. the labor (since i know you can't do it yourself if you're asking these kind of questions, no offense) will be hundreds.
i wouldn't recommend starting out with 100 shot though! once you get used to it and know what you are doing more or less you can upgrade to 75 or even 100 shot if you want JUST FOR THE TRACK. you really need to start at 35 shot to get comfy with it and keep it at 75 max while cruising. remember, no spraying below 3k rpms. i have custom jets that run my 90 shot for track use only. too bad i keep breaking down before i can mosey on over to the track though.
your stock fuel system will start to lean out at 100 shot.
-austin
07-16-2003, 01:54 AM
#3 | | Registered User
| Quote: |
Originally Posted by Danger Dude Quote: |
Originally Posted by MusclesFromBrussels guys dont forget some nice copper plugs too. | Yes Autolite Copper 1 heat range colder
Corey | i disagree!
he needs 2 stages colder for sure.
ford motorcraft AWSF 22-c's are my 90 shot plugs.
__________________ |
07-16-2003, 01:57 AM
#4 | | Registered User
| Quote: |
Originally Posted by jbone Quote: |
Originally Posted by Smokedya95stang A 100 shot will run 'safely' on a stock stang. Althought i wouldnt reccomend it. Especially after alot of sprays i doubt your engine would be to healthy. | If I spray at a safe RPM, I have been thinking of a kit that will only spray at WOT. | you realize that you can be below 3,000rpms (minmum before spraying) while flooring it, which would activate it, right?
07-16-2003, 04:49 AM
#5 | | Legacy Member
| Quote: |
Originally Posted by Smokedya95stang A 100 shot will run 'safely' on a stock stang. Althought i wouldnt reccomend it. Especially after alot of sprays i doubt your engine would be to healthy. | If I spray at a safe RPM, I have been thinking of a kit that will only spray at WOT. | you realize that you can be below 3,000rpms (minmum before spraying) while flooring it, which would activate it, right? | That is why I highly recommend a Window switch.
As for you disagreeing, alot of people using nitrous on V6 cars including me run along with the recommendations from Fordchip and Mikael at RPM use 1 heat range colder plugs like the autolite 764
But you can disagree this is an open forum.
Corey
07-16-2003, 08:50 AM
#6 | | Legacy Member
window switches are good, but i dont think they are necessary on auto cars. just because of the fact taht you wont ever reach too high of an rpm and it wont drop below 3000 while shifting. so as long as the user has some common sense, he can just flip it at 3000 and be fine. manuals i do suggests because they can revi higher on accident, or shift too slow and accidently drop below 3000. (i have sprayed at 2300rpms before on a 75 shot and it was off the line w/ slicks.. got the front of my car up some, but still a little dangerous  )
autolite 764s are almost necessary. you can use your stock platinum, but i wouldnt for very long. just not worth the risk.
07-16-2003, 11:02 AM
#7 | | Registered User
after you get used to it, the WOT switch works fine. you can do it either way, but i consider the WOT to be the safest of the switches. at least when you ARE flooring it the rpms are on the up and up, whereas i would be paranoid i'd hit the switch at 1500 rpms or something. either way does the job!
what kind of traction do you have threadstarternitrousdude? if you have regular street tires, you won't get all that much from a 100 shot because you will lose traction for sure and hurt your ETs. might want to invest in a pair of drag radials. i'm assuming your read end is stock? i guess you shouldn't go with DR's until you upgrade your drivetrain.
07-26-2003, 04:24 AM
#8 | | Registered User
So is a 75 shot alright with just MAC dual exhaust and CAI?
__________________  2003 Black Cobra Coupe
Current Mods: Flowmaster Cat-Back & Tinted Windows
Future Mods: 18x10.5 HRE's, S-281 Spoiler & Side Scoops, & KB Blowzilla
Red, White, and Blue --- The Colors that Hold True
Previous Car: '01 Silver Vert V6 with MAC Cat-Back Dual Exhaust, CAI, 17x9 Chrome Cobra Rs, Billet Grill with Pony Insert
What Ford Needs to make the Next Gen SVT Cobra look like! http://www.mustangmods.com/data/1251...avatar_gmg.jpg |
07-26-2003, 08:33 AM
#9 | | Legacy Member
07-26-2003, 09:10 AM
#10 | | Legacy Member
| Quote: |
Originally Posted by Stang01 So is a 75 shot alright with just MAC dual exhaust and CAI? | yup
07-26-2003, 01:30 PM
#11 | | Registered User
| Rellik Quote: |
Stang01, if you blow up your car at the track, I'll give you a ride home
| Lets pray that doesnt happen
07-26-2003, 01:58 PM
#12 | | Legacy Member
be smart about it and you shouldnt harm your car in anyway. you read the sticky completly yet?
07-26-2003, 04:58 PM
#13 | | Registered User
ya
07-26-2003, 04:59 PM
#14 | | Registered User
i just need to find a system for cheaper than its going for.
07-26-2003, 06:48 PM
#15 | | Legacy Member
Check out ebay. They sell kits.
08-04-2003, 06:02 PM
#16 | | Registered User
NX kit: $465 how does this price sound?
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
08-04-2003, 06:23 PM
#17 | | Legacy Member
good avg price is $450ish so its not much more
08-04-2003, 06:59 PM
#18 | | Registered User
i got the /basic/ NX kit for 500 after tax. so prob 475$ or so before tax.
08-04-2003, 07:45 PM
#19 | | Legacy Member
Sounds good to me
08-04-2003, 07:48 PM
#20 | | Legacy Member
Sounds good to me I was going to buy a NX kit when a super super deal came to me on ebay one morning with 1 hr left at 4:00 am and picked up a Nitrous works 25-150 wet kit for $ 280 new from bennett racing in Alabama
08-04-2003, 10:11 PM
#21 | | Registered User
After reading all the replies i've finally decided to save my money and go with a 75 shot instead of a 100 shot. Before I buy my kit though, I have 3 questions I was hoping yall might help me with. Please forgive me if their dumb or have already been covered  (I used the search and i read Monkey's stickey before I asked)
1) What exactly does a 75 shot feel like? Is it a big time increase in acceleration?
2) On an almost stock car, what kind of 1/4 mile improvements can i expect
3) With a 75 shot of Nitrous on an auto and, cai, dual exhaust, gears, t-loc, udp, chip and a shift kit, any idea what I'll run the 1/4 in?
Thanks again for all the help!
08-04-2003, 11:38 PM
#22 | | Legacy Member
1) feels like another gear. not a kick in the pants like seen in movies, but like the car shifts and just pulls in that "new" gear.
2) 75 shot is good for about 1.0 sec off your ET
3) im assuming you have an auto cause of the shift kit.. if so, then i would say 13.7s-14.1s (stock 01 auto is good for 15.4s.. minus second for nitrous, minus .3 for gears.. mine .2 for everything else = 13.9 but depending on conditions and if your car runs well or not there is variation)
08-05-2003, 09:20 PM
#23 | | Registered User
Thanks Monkey. 13.7-14.1 Sounds good to me !
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | 75 shot? | tigerfan2771 | Pre-2005 V6 Mustang | 49 | 07-01-2008 06:37 AM | | Someone Needs To Get SHOT | bluemustang | Pictures and Videos | 16 | 10-26-2006 11:02 PM | | 100 shot | knife13 | Pre-2005 V6 Mustang | 7 | 05-06-2004 11:09 AM | |
