need answer soon please - Mustang Evolution
Old 02-27-2014, 12:29 PM   #1
Question need answer soon please
I have a 98 v6 and found a auto trans from an 01 on Craig's list can I put the 01 trans in my 98
princeofkings86 is offline   Reply With Quote
Old 02-27-2014, 12:52 PM   #2
Region: Nevada
Maybe with some custom work. just like its possible to put an evo engine in a stang. just depends on if you have the time and money to do it.
Bluestallion is offline   Reply With Quote
Old 02-27-2014, 12:54 PM   #3
I have the time but don't really have the money so I can't just pull mine and drop the one from an 01 in?
Old 02-27-2014, 01:14 PM   #4
lemons95's Avatar
Same bolt pattern, it'll bolt up. Might need to get an 99-04 crossmember. I don't know of the electronics will work though.
Old 02-27-2014, 04:13 PM   #5
I sent the owner of the trans and he said it is compatible but I want to check here cause his opinion is a little biast
Old 02-27-2014, 06:55 PM   #6
samuelsmith's Avatar
Here is what I found. If you do not fix this your speedometer will not work.
how to use a 99+ t5 in a 94-98 - V6Power Messageboard
Old 02-27-2014, 07:10 PM   #7
Is $200 a good price for a trans with 70k miles
Sent from my XT1080 using Tapatalk
Old 02-27-2014, 09:14 PM   #8
Same transmissions 4r70w but you wont have a speedometer connection for the 01. Your 98 has a different tailshaft connection.
Bigshow14 is offline   Reply With Quote
Old 02-27-2014, 09:16 PM   #9
Is it hard to change the tailshaft?
Old 02-27-2014, 09:17 PM   #10
olds442111's Avatar
Send a message via AIM to olds442111
Price is right for sure, provided it functions properly, and you can adapt it in.
White 2014 GT Premium / Blower / Auto Trans / Louisiana
Blue 2016 Sport FX4 Crewcab / Blower coming soon
olds442111 is offline   Reply With Quote
Old 02-27-2014, 09:18 PM   #11
The car sounds like it was rear passenger that got all the damage
Old 02-27-2014, 09:21 PM   #12
olds442111's Avatar
Tailshaft isn't hard to change. For most folks I'd say it's doable.
Old 02-27-2014, 09:23 PM   #13
I am pretty mechanicly inclined I just havent done much on transmissions... Mostly old vw engines...
Old 02-27-2014, 09:23 PM   #14
You cant change the tailshaft on those transmissions. if your in a bind for a transmission look into the one on craigslist for short term. You can have your 98 trans rebuilt and reinstall it later.
Old 02-27-2014, 09:24 PM   #15
olds442111's Avatar
4r70 doesn't have a removable tailshaft?
Old 02-27-2014, 09:27 PM   #16
That's where I found the one I found... The car runs great I just manually sift to second from drive when the rpms get to about 4 then when back to 4 I put it back in drive its just a pain cause I can't just floor it to pass people on the freeway
Old 02-27-2014, 09:29 PM   #17
How do I identify which tranny it is cause I've read a lot and seems like 98 was the switch from one to the other
Old 02-27-2014, 09:29 PM   #18
Now your making me double guess myself I owned a 98 v6 and cant remember. I changed out the speedo gear when I installed the 3.73s but its been awhile
Old 02-27-2014, 09:30 PM   #19
My stang was manufactured 04/98
Old 02-27-2014, 09:32 PM   #20
olds442111's Avatar
LMAO, we all have our moments. The junk in our heads gets jumbled together.
Old 02-27-2014, 09:33 PM   #21
98 was the 1st year for the 4r70w. The 4.6 has one but the bolt pattern is different than the 3.8. The 96-97 3.8 trans will work just not as good of a trans compared to the 98
Old 02-27-2014, 09:33 PM   #22
I hear that
Old 02-27-2014, 09:36 PM   #23
Especially when you been working on stangs from 1984 to 2014 models its hard to keep up
Old 02-27-2014, 09:37 PM   #24
olds442111's Avatar
I understand, trust me
The tailshaft is removable on 4r70 automatics
Old 02-27-2014, 09:37 PM   #25
Ok I guess its back to craigslist
Old 02-27-2014, 09:43 PM   #26
Yeah I just googled it. I must have had the bell housing on my mind. The birthdays are starting to catch up with me
Old 02-27-2014, 09:48 PM   #27
Ok so that 01 trans will work
Old 02-27-2014, 09:53 PM   #28
Yeah the speedometer will be the only issue
Old 02-27-2014, 09:59 PM   #29
And I just have to swap the tailshaft to fix the speedo issue right
Old 02-27-2014, 10:05 PM   #30
I had this same question on my truck a while back with the speedo. I could have changed the tailshaft but the output shaft on the transmission didn't have the gear on it so it STILL wouldn't have worked.
Id make for damn sure that the later model transmissions still have the speedometer gear on the output shaft otherwise that has to be changed as well.
And that requires a complete disassembly of the transmission...
Old 02-27-2014, 10:09 PM   #31
Ooooo k in light of that isnt there some sort of converter I could install since the speedo is full electronic
Old 02-27-2014, 10:12 PM   #32
olds442111's Avatar
Not that I'm aware of. But technology is always changing. Maybe there is.
Old 02-27-2014, 10:16 PM   #33
Do some researching on a speed cal. What gears do you have in the rear?
Old 02-27-2014, 10:16 PM   #34
I think that it will be easier to find the correct transmission.
Old 02-27-2014, 10:33 PM   #35
olds442111's Avatar
+1 ^^^
GT500 Strut Mount and Stock Struts, Can't Find Definite Answer TheRoadWarrior 2011-2014 Mustang GT 19 01-19-2014 06:10 AM
I NEED A FAST ANSWER! 2002 gt engine swap for 1995 mustang lemons95 Pre-2005 V6 Mustang 7 07-06-2013 02:37 AM
Nos... Just read and maybe answer?! Mustang_Madness 1996-2004 Mustang GT 24 03-06-2012 05:04 AM
I need a solid answer asap please! BossFiveOh 2011-2014 Mustang GT 2 01-30-2012 07:44 PM
4:10 gears qusetion. need answer asap mhobbs 1996-2004 Mustang GT 4 08-19-2011 10:55 PM
04:23 AM
