lil shifting problem - Mustang Evolution
Old 02-27-2014, 12:36 PM   #1
Unhappy lil shifting problem
I have a 98 v6 automatic and it just started sticking in first and if I'm going like 60 on the freeway and step on it to pass it shifts to far and pushes the tack into the red then once I take my foot off the gas a few seconds later it shifts back to the proper gear
Any advise would be great I would prefer any option that doesn't require removing the tranny cause I don't have a lift but have the tools if it's the only choice
princeofkings86 is offline   Reply With Quote
Old 02-27-2014, 02:47 PM   #2
Getn off's Avatar
First thing to check is the fluid level. Make sure it is done correctly. Can't remember if ur car needs to be at idle and in gear to check level or not. Read up in the manual. But def check to see if ur low on fluid.
Troy
Getn off is offline   Reply With Quote
Old 02-27-2014, 03:27 PM   #3
I checked the fluid and it seems very fresh and over full would overfilling cause any problems?
Old 02-27-2014, 03:30 PM   #4
samuelsmith's Avatar
Did you crank it up, leave it in neutral, wait a few mins., and check the dip stick
Old 02-27-2014, 04:07 PM   #5
I drove about 1/4 mile to a level parking spot put the shifter through all the gears then back to neutral and checked the dipstick and it looks like it covers all the white plastic
Old 02-27-2014, 04:20 PM   #6
I found a transmission from a 01 the crashed with 75k miles for 200 would that work
Sent from my XT1080 using Tapatalk
Black headlight covers problem GTstang07 2005-2010 Mustang GT 22 01-11-2012 11:29 PM
95 cobra start problem jhagan1980 SVT Mustang 1 01-06-2012 04:51 PM
Cut out problem 89white GT 1979-1995 Mustang GT 3 01-05-2012 05:48 AM
Shift knob problem with steeda tri-ax apex32 2011-2014 Mustang GT 5 06-29-2011 01:04 PM
02:28 AM
