HUGE throttle lag - Mustang Evolution
Old 02-28-2014, 07:37 AM   #1
HUGE throttle lag
2003 V6 Mustang 5spd 120k miles
I just got this car. I noticed that there is a major lag in responsiveness. Is this normal? Is there a correction? There is at least a 1 second delay. This affects shifting severely. When I let the clutch out and press the gas the car wants to stop because there is no power being applied yet even though my foot is on the throttle. Finally, one second later, the rpm start to climb. It's horrible. I can make a video if my problem is not clear. It doesn't just happen when I'm trying to shift it happens even if I just rev the motor in neutral. The pedal is set up right. It's something else.
Thank you.
njdurkin is offline   Reply With Quote
Old 02-28-2014, 04:09 PM   #2
JimmyMosqueda's Avatar
Try the ignition system. Coil pack, wires, and plugs. Clean EGR valve and IAC. The most expensive problem might be clogged catalytic converters.
Sent from my Pager
JimmyMosqueda is offline   Reply With Quote
Old 02-28-2014, 04:21 PM   #3
samuelsmith's Avatar
I would got to Autozone and have the codes ran. Write the codes down and come back.
Old 02-28-2014, 06:11 PM   #4
After checking what JIMMY mentioned, just quickly look at or wiggle the air intake, pcv connection, MAF connection, air filter connection, vacuum hose connections, TB & air intake connection.?.?
Old 02-28-2014, 07:47 PM   #5
lemons95's Avatar
Fuel injectors?
Old 03-01-2014, 07:26 AM   #6
After experimenting, it's only about a 2/3 second delay. I also noticed that when I rev my car, it stays reved for a REALLY long time. Is this just what mustangs do? I rev it to 3.5k and it slowly goes down. I mean literally 4 seconds just to get to 2k. I'm used to cars reving to 6k and going back near idle in 2-2.5 seconds. Maybe this is a window into what is causing the lag. I will start trying all of your suggestions when I get a nice day to work on it. Which won't be soon because I'm supposed to get 8" of snow tomorrow night :/
Old 03-01-2014, 08:59 AM   #7
Definitely not normal for such a delay to get to idle. Keep us posted!
Sent from my Pager
Old 03-01-2014, 07:03 PM   #8
Bravebowhunter's Avatar
The engine hovering like that is the iac. There's nothing wrong with it that's just how it's set up. You can make a play to go between the iac and the intake to prevent so much air from going through the iac and it will go from 3k back to idle real fast. To do this mod go to the store buy two iac gaskets and trace the gasket onto a piece of metal cut out the shape then when you drill out the holes drill one the stock size and drill the other one 3/16 inch and put it in with the 3/16 hole on the vacuum side away from the throttle body. this will fix that hover.
Bravebowhunter is offline   Reply With Quote
03 throttlebody briankiel 1996-2004 Mustang GT 26 01-05-2013 04:00 PM
1987 Mustang GT 5.0: Huge Help Needed Johnson 1979-1995 Mustang GT 24 01-18-2012 08:19 PM
62mm bore throttle bodies on naturally aspirated 05-09 mustangs 08 Bullitt 2005-2010 Mustang GT 40 01-16-2012 01:36 PM
00 to 01-04 throttle cable conversion ForsakenProto Pre-2005 V6 Mustang 1 11-18-2011 09:44 AM
Throttle Body Spacers jbanks 1996-2004 Mustang GT 5 07-11-2011 08:43 PM
05:51 AM
