Freaking out - Spider Gear problems! - Mustang Evolution
Old 02-28-2014, 01:28 PM   #1
Exclamation Freaking out - Spider Gear problems!
Hi,
Ok, try to make this quick. Problem with the car, brought to the mechanic. He attempted to drive it and knew what problem was right away. The spider gears in the rear-end went.
The mechanic then orders replacement spider gears from Ford, however, they don't fit. He calls me and tells me that I have two options: 1 - to replace the entire rear end of the car with a used one from another car, which will cost around $600 (plus labor) or 2 - he can replace the 3.73 gears and change everything over to stock, which will cost about the same as option 1. I'm freaking out at this point. My mechanic says because he doesn't know the make of the 7.5" LSD that he doesn't know where to get the spider gears from.
So, I contact the person I purchased the car from and he informs me that he put in a 7.5" LSD from Ford Racing. I contact Ford Racing and, they don't make spider gears for 02's anymore, it's not offered in their catalog or online. However, the guy from Ford Racing said that I can replace the inside of the LSD and should be able to get the parts from a local auto store for about $200. I contacted the local auto parts store and the person I spoke to confirmed it and said that I could actually upgrade the inside of the LSD from 3.73 gears to 410 gears for around $190.
Now, my questions are: the inside of the LSD includes the ring & pinion but, does it also include the spider gears and whatever else is needed to fix the problem? AND, this fix is possible right, what I'm being told is true, that I can replace the inside of the LSD? AND also, shouldn't my mechanic have suggested this once he found out the the LSD was from Ford Racing and spider gears aren't available?
Sorry for all the questions, but, I'm at my wits end. I need my car for work and it's costing me money everyday that it's not running.
Oh and BTW my name is Alleen. Lucille is my car's name!
Thanks for any help/answers I really appreciate it!
Alleen
Lucille is offline   Reply With Quote
Old 02-28-2014, 04:07 PM   #2
JimmyMosqueda's Avatar
Personally I'd swap to a GT Rear. You could probably find one for 150 if you're lucky. Install is simple. Bolts directly on.
Sent from my Pager
JimmyMosqueda is offline   Reply With Quote
Old 02-28-2014, 04:23 PM   #3
samuelsmith's Avatar
A Gt rear would be your best bet and probably the same price. You would need a tune to fix your speedometer.
Old 02-28-2014, 05:07 PM   #4
The locker has nothing to do with the ring and pinion...
Sent from my massive johnson.
Old 02-28-2014, 07:51 PM   #5
lemons95's Avatar
I agree with the gt rear, the 8.8 is a much stronger rear-end with parts readily available. What's even better is a 8.8 is a direct bolt in. No modification needed it could be done in a few hours if you do the work yourself.
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Gear Lash?? 2014 GT new ThunderKissGT 2011-2014 Mustang GT 15 06-16-2013 08:46 AM
Gear Options with MT82, Boss IM and Tall Tires Napoleon85 2011-2014 Mustang GT 2 04-22-2012 06:44 PM
Newbie: Is this normal? (Finding first gear & backfiring) Rim 2011-2014 V6 Mustang 9 03-07-2012 06:10 AM
2000 V6 problems iphonemaster93 2.3 Mustang 47 01-12-2012 12:10 AM
04:27 PM
