Rusty Clutch Cable? - Mustang Evolution
Old 03-02-2014, 07:01 AM   #1
Rusty Clutch Cable?
I'm not sure if this is the problem, but it's what I have read online. 120k miles on original clutch. It feels like there is a LOT of friction going on. For example, when you depress the clutch pedal, it seems sort of stuck if you don't apply much pressure. Then, as you add pressure, eventually it breaks free and jumps an inch or so and stops. It feels like something hasn't been lubricated that needs lubricated. It is a little difficult to control the pedal precisely because of all of the friction. You can also hear it make a lot of squeaky sort of noise as you use it. I'm not saying that a rusty clutch cable is the problem but what is the first step to fixing this issue?
Thanks guys. You're awesome!
njdurkin is offline   Reply With Quote
Old 03-13-2014, 12:20 PM   #2
h1ck55ter's Avatar
get a new cable, and while your at it get the steeda quadrant and adjustable firewall piece, you might as well change the clutch fork while your at it.
Polished heads, stock lower, 3.8 bottom end, Mac Pro Dumps, Mac O/R H-pipe, Pacesetter lt's, SCT xf3 (93 Ortizperformance tune), 03-04 Cobra tb, Lightning MAF, BBK CAI, Stage 2 water/meth kit, 310 LPH Fuel Pump, 39lbs blue top injectors, Mach 1 8.8 w/ 3.55's, steeda springs 1.5", Bilstien shocks/struts,Steeda Caster Camber Plates, M112 blower w/ 3.1 Pulley
h1ck55ter is offline   Reply With Quote
Clutch cable Cstyle1 1996-2004 Mustang GT 2 01-27-2014 05:05 PM
Clutch Cable cmonro2 1996-2004 Mustang GT 16 12-23-2013 10:32 PM
Transmission fluid for the T5 Combatman 2005-2010 V6 Mustang 18 08-05-2013 04:23 AM
clutch cable issues 89stang 1979-1995 Mustang GT 12 12-27-2011 10:30 PM
Clutch cable broke... Need help... BLUE02GT 1996-2004 Mustang GT 4 09-15-2011 10:36 AM
12:37 PM
