fuel pump no start - Mustang Evolution
Old 03-04-2014, 12:36 AM   #1
fuel pump no start
Fuses good, pump good, inertia switch new, no power at pin 5 at ccrm but other pins are good. Fuel pump plug not recievin power but fuel gauge is
zachcouuts is offline   Reply With Quote
Old 03-13-2014, 11:05 AM   #2
h1ck55ter's Avatar
i sent you a post on mustang forums, but try to run the wires all the way back and see if you have a break in the line, or if its grounding out some where.
h1ck55ter is offline   Reply With Quote
Old 03-14-2014, 12:30 PM   #3
PRoss.20's Avatar
Region: Arkansas
I had the same problem and then I realized somehow the emergency cut off switch in my trunk had been pressed. Pushed it and everything was fine.
PRoss.20 is offline   Reply With Quote
Old 03-14-2014, 03:23 PM   #4
Definetly a ground problem, inertia switch is fine and new in fact. But I can't find where the problem is for the life of me.
Mustang for Fuel Efficiency- Ohio 2012 3.7 to RS UltArc New Member Introductions & Greetings 79 04-09-2015 07:50 PM
eBay fuel pump 2000stanguy Pre-2005 V6 Mustang 2 01-16-2014 03:58 PM
3.8l 2000 manual starting issue Lousiffer Pre-2005 V6 Mustang 12 11-16-2012 11:10 PM
95 gt 5.0 fuel pump ? durtyred69 1979-1995 Mustang GT 4 02-15-2012 09:01 PM
Fun Ford Weekend and Super Chevy Shows Welcome Aeromotive Fuel Systems as Series Spo FunFordWeekend At the Track 7 02-09-2012 07:02 PM
05:11 AM
