Alfredo - Mustang Evolution
Old 03-04-2014, 01:02 PM   #1
Alfredo
My 2000 Mustang 3.8 V6 5 gear was idling at 1300-1500 rpm.
I cleaned the IAC valve but then it made a weird 'screeching' noise from somewhere
in the throttle body and cut out when I took my foot off the accelerator.
I put it in the garage and they replaced the IAC, but they could only find a used unit to replace it with (I live in Spain).
The car still idles at 1500 rpm until it has been driven for some time. This is a nuisance, especially when using the engine to reduce speed on downhill stretches. My manual says it is not possible to adjust the idle speed and that I should take it to a Ford dealer.
Any suggestions please?
Alfredo is offline   Reply With Quote
Old 03-04-2014, 02:46 PM   #2
I had a similar problem on mine. You may try Ebay to get a new or Reman unit. I cleaned my iac valve, replaced the camshaft sensor and synchronizer, spark plugs and wires and had an oil change. now it idles at 800 when hot. I think the synchronizer was the problem in mine. I'd try replacing that and sensor first
Sent from my MB865 using Mustang Evolution mobile app
alexfraley is offline   Reply With Quote
Old 03-04-2014, 05:12 PM   #3
samuelsmith's Avatar
Contact sellers on Ebay, many will ship overseas for a extra fee.
Alfredo Alfredo New Member Introductions & Greetings 13 02-20-2014 02:16 PM
Alfredo Alfredo Pre-2005 V6 Mustang 6 02-07-2014 07:29 AM
04:34 AM
