Crazy plan for dual exhaust. THOUGHTS?? - Mustang Evolution
Old 03-04-2014, 02:02 PM   #1
Alright, before I begin let me set the background. I have a 2004 v6 Mustang. IMPORTANT NOTE: I lowered the car by cutting springs (probably sits 1.5 in lower? never measured.)
Anyway, the goal/mission: To convert my single exhaust mustang to an Pacesetter h-pipe dual exhaust set up with Flowmaster Super 44s for AS CHEAP AS POSSIBLE. This is where I need the help from MustangEvolution. Review these possible routes I can take and reply with thoughts/concerns or other routes I didnt think of....
Also, I am a teen driver and by no means mechanically knowledgable in the field but have done extensive research on nearly everything I mention. I have cute springs, replaced shocks and done a CAI myself with a bunch of appearance mods etc.
Route 1.) A local exhaust shop said they would do what I want for about $350 *IF* I purchase the mufflers myself. 350+160(Flowmaster mufflers)= $510 total. (The shop said that if I buy the H-pipe he could take off maybe $100). So between $510-555
Route 2.) In an attempt to save money on the cost of labor... cutting the y-pipe myself, installing the h-pipe myself and driving to the exhaust shop to have them finish the job (welding mufflers and the rest etc). I also would encounter issues getting to the exhaust shop because I would be driving without mufflers or any pipes at all (dangerous? Loud? legal issues?)
$160 for mufflers + $145 for H-pipe + ???? for labor.
Things to consider: How can I reduce bottom line costs? Should I have the shop custom fab an H-pipe? Would that reduce or increase labor/bottomline costs? Should I do it myself? Is there something I haven't thought about?
Edit: Keep in mind any clearance issues I might have due to lowering the car.
zachsola is offline   Reply With Quote
Old 03-04-2014, 05:19 PM   #2
samuelsmith's Avatar
The v-6 Mustang is not that loud. Do not remove headers and drive. You chance burning up a valve. Before I got a Pypes duel exhaust the previous owner welded a pipe into the y to have duel exhaust. Just another idea.
The exhaust sounded good. Eventually the cats went bad and I replaced everything.
Old 03-04-2014, 11:12 PM   #3
Buy an offroad h-pipe from Jegs and a pair of flow tubes(pipe in front of the muffler) you can try and craigslist/junkyard some gt tailpipes or you can by a pair of 87-93gt tailpipes and they will turndown right at the back bumper. I would avoid welding the exhaust where it's not removeable if needed. A friend of mine did the muffler shop duels and ended up ripping it out on the first transmission removal. He went back with after market exhaust. I used the thrush welded mufflers on my 98v6 they look identical to the flowmasters just not as loud and are about $35 each.
Bigshow14 is offline   Reply With Quote
Old 03-06-2014, 02:03 PM   #4
Thank you very much for the help, definitely got me thinking!
Old 03-06-2014, 02:07 PM   #5
I have one more question in regards to your 87-93 GT comment.
Would I be able to purchase the American Thunder Catback exhaust for 87-93 GTs (Flowmaster American Thunder Mustang Catback Exhaust System 17116 (87-93 GT) - Free Shipping) and install it on my 99-04? Im only asking because this catback includes the super 44s, while the 99-04 American thunder does not... Any thoughts on doing that? what kind of fab would be required?
Old 03-14-2014, 06:31 AM   #6
black04v6's Avatar
Don't get the pacesetter headers. They are a pain in the as to install. If you have a shop do it labor will be high. If you do it yourself you'll need to lift the engine up. BBK makes headers that fit better. Just a tip as I have pacesetters and it took a long time to put in.
black04v6 is offline   Reply With Quote
Old 03-14-2014, 07:32 AM   #7
Pacesetter headers and headers in general weren't mentioned in this thread. Only the pacesetter h pipe adapter
Old 03-14-2014, 08:17 AM   #8
It will work but you will need to change the exhaust hangers. You can use hangers from 86gt to 97gt.
exhaust
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
Exhaust: Pro Dumps Mdavis1024 1979-1995 Mustang GT 6 01-15-2012 07:50 AM
Good Information Thread. ESG642T Pre-2005 V6 Mustang 10 01-13-2012 08:00 AM
3.8 Dual Exhaust ssaleen1981 Pre-2005 V6 Mustang 27 12-18-2011 06:43 AM
02:36 PM
