Mustang header glowing red hot and idle is high. - Mustang Evolution
Old 03-06-2014, 04:29 PM   #1
kickerofdoom's Avatar
I tried to seafoam and helped a bit but it's either bad car, iac or some other random help anyone seen this problem before
Old 03-06-2014, 04:49 PM   #2
Maybe a bad converter.
Bigshow14 is offline   Reply With Quote
Old 03-06-2014, 04:55 PM   #3
Site Sponsor
Sponsor
AMWill's Avatar
I'd put my money on a clogged catalytic converter. There's really not much else that would cause a header to get red hot during idle with a Naturally Aspirated engine. Is it just one header or both getting red hot?
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 03-06-2014, 04:56 PM   #4
Both but would that cause the idle to be high like 2000rpm and the idle to hang when you press the gas. Could a tps cause a problem
Old 03-06-2014, 05:19 PM   #5
samuelsmith's Avatar
Have someone crank your car and tell you when they push on the gas. You put your hand near the exhaust. If there is a delay in the exhaust escaping. The cats are clogged.
Old 03-07-2014, 09:16 PM   #6
baddbradd's Avatar
Also, when its dark out, let it idle for a few minutes. if the cat is glowing , its stopped up.
2001 coupe
baddbradd is offline   Reply With Quote
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
11:07 PM
