Older Exhaust manifolds - Mustang Evolution
Old 03-10-2014, 11:04 AM   #1
SpeedyG's Avatar
My exhaust manifold or headers have cracked and now making a ticking noise in the engine bay. I have read somewhere that you can put on older manifolds from the previous model and that they are better. True or false? Better or not?
SpeedyG is offline   Reply With Quote
Old 03-10-2014, 11:23 AM   #2
Adogg's Avatar
I'm pretty sure your car came with an exhaust manifold. Unless you are switching to a set of stock shorty headers you won't see much gains. And even if you are switching to a set of stock shorty header there still won't be much of a gain if any at all. Would recommend just getting oem replacement for best fitment. If you really want you could get some aftermarket shorty headers.
Don't hate....... appreciate
Old 03-10-2014, 12:55 PM   #3
sebasflorez's Avatar
Yes. You can get the stock shorty headers off the 94-98 v6 mustangs.
sebasflorez is offline   Reply With Quote
Old 03-11-2014, 07:44 PM   #4
You could always take them to a shop and pay a couple bucks to weld them where they were cracked if it's a minor crack like mine were. It works like a charm better then spending a couple hundred or something if it's only your DD
03svt_swap is offline   Reply With Quote
Old 03-11-2014, 09:47 PM   #5
SpeedyG's Avatar
Are the older model headers better than the newer ones??
Old 03-11-2014, 10:42 PM   #6
Definitely, because they're actually headers, not exhaust manifolds like 99-04 are. Plus, you can get them CHEAP at a junkyard.
Old 03-11-2014, 10:43 PM   #7
SpeedyG's Avatar
Thanks for the info man! Will get them soon!
Old 03-11-2014, 10:46 PM   #8
No problem man, just one more thing, i read somewhere on here the 94-98 are 1/4" larger where they connect to the midpipe, so you may need a shop to help you adapt them, or maybe you can do it yourself? That's the one thing I don't know how to get around. Maybe someone with a bit more knowledge on this will chime in soon.
Old 03-11-2014, 10:48 PM   #9
http://m.mustangforums.com/forum/sho...=283370&page=2
This should help you out
Old 03-13-2014, 09:55 AM   #10
baddbradd's Avatar
the collector outlet of the 96 manifolds is 1/4 bigger. My 01 factory was more of a log type. If I can find comparison pics, I will post them
2001 coupe
baddbradd is offline   Reply With Quote
exhaust
dual exhaust Aaron88 2005-2010 V6 Mustang 0 02-10-2014 07:01 PM
dual exhaust Aaron88 2005-2010 V6 Mustang 0 02-10-2014 06:48 PM
Dual exhaust? Crafty615 Pre-2005 V6 Mustang 105 06-07-2012 10:22 PM
Tuner vs Exhaust? JCOB72 1996-2004 Mustang GT 43 03-07-2012 05:38 AM
Doesnt like these exhaust Blackedout Pre-2005 V6 Mustang 40 06-30-2011 08:50 PM
08:29 AM
