Problems - Mustang Evolution
Old 03-10-2014, 01:25 PM   #1
acwatson03's Avatar
Problems
Hey guys I'm new to this and this is my first post need guidance and advice.
I have an 03 3.8L and for a while now I've had bad hesitation and what feels like a skip but it's throwing no codes. Ive replaces plugs w/OEM motor craft platinums and replaced wires to Bosch. I've checked for vacuum leaks but nothing and even tho the lights off I plug my obd and get p0316 (crank sensor) so I replaces it and I disconnected my battery to reset computer and it ran better until I started driving more and all the problems came back. A mechanic told me it's recommended to replace the cam shaft synchronizer so I did and I was very careful to make sure if put the new one in exactly as the first one and I disconnected the battery again. Seemed like it was rerunning perfect then all my problems came back, I cleaned the egr also of a recommendation and still same thing. Also recently noticed it started back firing throughout the intake. Anyone else have these problems? Any help would be great thanks!
acwatson03 is offline   Reply With Quote
Old 03-10-2014, 03:24 PM   #2
sebasflorez's Avatar
Coil pack my man, had the EXACT same problem, started by changing plugs, then crankshaft sensor, then wires, and finally changed the coil pack and the problem went away.
sebasflorez is offline   Reply With Quote
Old 03-21-2014, 11:26 AM   #3
acwatson03's Avatar
That was it thanks man!
Old 03-21-2014, 11:45 AM   #4
No problem! Does the ticking you mentioned on the other thread go away after the car's warmed up? If so it is a cracked exhaust manifold. Happens because the AC drips on the hot manifold which makes it crack, very common with 99-04 V6's, usually doesn't affect anything.
Old 03-21-2014, 11:50 AM   #5
acwatson03's Avatar
I do have a exhaust leak at the passenger side manifold would that make ticking noise? I found it when I was running sea foam through my intake smoke just poured out of it
Old 03-21-2014, 01:04 PM   #6
Yep, that's what could be causing it. Try replacing the manifold or use jb weld on the leak
Old 03-21-2014, 01:08 PM   #7
acwatson03's Avatar
Could that also create a performance issue like a slight hesitation?
Old 03-21-2014, 02:04 PM   #8
OfficialMakkyZ's Avatar
That ticking is definitely coming from that manifold. Try JB weld, if that doesn't work, replace it.
I'm not sure about hesitation, but your back pressure will lessen.
Check out my garage:
http://www.mustangevolution.com/forum/f376/t351203/
OfficialMakkyZ is offline   Reply With Quote
Old 03-21-2014, 05:08 PM   #9
acwatson03's Avatar
Ok thanks guys I just bought the gasket and I'll take it off tomorrow and inspect and I'll let you know how bit goes
Old 03-21-2014, 09:16 PM   #10
baddbradd's Avatar
replace that manifold....
2001 coupe
baddbradd is offline   Reply With Quote
Old 03-22-2014, 10:57 AM   #11
[QUO TE=acwatson03;1974034]Ok thanks guys I just bought the gasket and I'll take it off tomorrow and inspect and I'll let you know how bit goes[/QUOTE]
Old 03-22-2014, 05:50 PM   #12
acwatson03's Avatar
The manifold was still good no cracks and I put a new gasket still has ticking noise but it's much quieter and sounds like it's from the other side now so I'm going to do the same thing and hopefully it clears up after that! On a different subject my power steering unit to me sounds a bit noisy, it's always made the same noise and it's perfect on fluid and steers easily would it quiet it down if I replace it
Old 03-26-2014, 07:35 PM   #13
acwatson03's Avatar
Ok I replaced both exhaust gaskets and inspected the manifolds and no cracks on them. Still making the ticking tho.
Old 03-26-2014, 07:39 PM   #14
acwatson03's Avatar
Problems
Old 03-26-2014, 07:49 PM   #15
My power steering is loud too, I think it's just a stang thing. Let me know if you replace it though!
Old 03-26-2014, 08:06 PM   #16
acwatson03's Avatar
I replaced it today too it's just as loud as the first so it's def a mustang thing
Old 03-26-2014, 11:35 PM   #17
Good to know! Too bad there isn't a way to silence it, but whatever. Haha
Old 09-30-2014, 10:32 AM   #18
Dman84's Avatar
I have a 2005 GT and I'm having issues with 2nd gear. When I'm driving and go from 1st to 2nd it grinds the gear.. I have to baby it to get it to go into gear and its a 50/50 chance that it will. I don't have any problems with the other gears besides 2nd?? Any ideas on what it might be I need help
Dman84 is offline   Reply With Quote
Solved all the MT82 problems with new Clutch Kit mustangcito 2011-2014 Mustang GT 11 10-25-2014 02:30 AM
After market hood problems???? Jsmorley81 2011-2014 Mustang GT 7 03-01-2014 03:01 PM
2012 GT engine problems?? jjl3717 2011-2014 Mustang GT 15 02-09-2014 09:00 AM
1998 V6 SCT eliminator chip problems RyanMc Pre-2005 V6 Mustang 4 01-10-2014 05:36 PM
2000 V6 problems iphonemaster93 2.3 Mustang 47 01-12-2012 12:10 AM
11:54 PM
