Supercoupe motor - Mustang Evolution
Old 03-10-2014, 08:56 PM   #1
97cutomstang's Avatar
Supercoupe motor
I found a complete motor but the guy does not know what year vehicle it came from. I have a 97 so will any year motor work?
97cutomstang is offline   Reply With Quote
Old 03-14-2014, 12:34 PM   #2
PRoss.20's Avatar
Region: Arkansas
You'll want to do the exact same year if possible so it's a direct fit with no custom modifications or weird fits. With that being said I'm pretty sure 1995-2004 will work and need hardly and modification if any.
PRoss.20 is offline   Reply With Quote
Old 03-14-2014, 01:35 PM   #3
davidcseifert's Avatar
Region: Arkansas
All supercoupes are singleport so that saves trouble sorting things out with the fuel systems since your 97 is, you should be able to drop it in and hook up your lines to their rail. Wiring is something I haven't looking into, I know a few things change location like the iat sensor for one, so that would have to be extended, I remember there being a few things you have to modify otherwise. Getting the intake piping to work is another thing, you can use bits and pieces of the supercoupe stuff and then add on piping to make it work, would highly suggest upgrading the FMIC since the stock one is so small.
blower/new cam soon
Old 03-14-2014, 01:51 PM   #4
Ok thanks. I plan on installing a 255lph fuel pump. They guy thinks it a 93 and he has a wire harness for a mustang conversion. I go tomorrow to look/get it
Old 03-14-2014, 02:12 PM   #5
samuelsmith's Avatar
Prothane Motor Mounts installed in 12 V6 willb2305 2011-2014 V6 Mustang 11 05-26-2014 08:28 AM
Motor rebuild questions 2002VertGT 1996-2004 Mustang GT 25 03-07-2014 04:52 AM
Motor swap Wmcgrattan General Car Discussion 35 12-05-2012 04:36 AM
Motor Travis B 1979-1995 Mustang GT 4 11-16-2011 04:38 PM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
07:31 PM
