Dual overhead cam? V6 2000. - Mustang Evolution
Old 03-12-2014, 06:06 AM   #1
Veracadoro's Avatar
Has anyone done it or have some experience with it? I would like to look into doing it but I'm not sure if it's worth doing as opposed to just buying a v8. My cars already got a ton of visual mods so I'm a little attached
Veracadoro is offline   Reply With Quote
Old 03-12-2014, 06:21 AM   #2
DaBluedude's Avatar
What dohc heads were you planning on using???...
2003 Mach 1
Old 03-12-2014, 08:36 AM   #3
Veracadoro's Avatar
I'm not sure yet. This is going to be my first time building a motor up. I'm more looking for suggestions and yays or nays currentlt
Old 03-12-2014, 12:44 PM   #4
You would need different everything. The 3.8 is a pushrod motor.
Sent from my massive johnson.
Old 03-12-2014, 12:49 PM   #5
Veracadoro's Avatar
Ah. Okay. Well good to learn these things before I try to delve in.
Old 03-12-2014, 02:55 PM   #6
samuelsmith's Avatar
We have single cams. It's kinda like taking apart a simple wind up clock. I mark mine with white out on the timing chain, balancer, cam, and crank.
Old 03-12-2014, 04:17 PM   #7
Veracadoro's Avatar
But has the change been done? Is it possible?
Old 03-12-2014, 04:32 PM   #8
I have a 207/215 .050/.050 112 lsa cam for a future mod. You have to change the rocker arms if you get a decent cam, springs, retainers, and push rods to get perfect roller geometry. You need a tune also. It is a serious mod for serious mustang m-o-d-d-e-r-s. It takes a high level of mechanical knowledge to do this yourself.
Old 03-12-2014, 04:36 PM   #9
Veracadoro's Avatar
Cool, I'm wanting to have some fun with it. A friend of mine told me he switched his from single to dual overhead cams I never asked how
Old 03-12-2014, 08:52 PM   #10
3 things come to mind
1 he is from Colorado.......smoking that GOOD! GOOD!
2 he does not know what he is talking about
3 he is a master engineer
Old 03-13-2014, 03:32 AM   #11
DaBluedude's Avatar
He lied. It's not feasible at all. He's probably full of it.
2003 Mach 1
Old 03-13-2014, 09:48 AM   #12
baddbradd's Avatar
find a new friend that not trippin'
2001 coupe
baddbradd is offline   Reply With Quote
Old 03-13-2014, 10:25 AM   #13
Veracadoro's Avatar
Alright. So going with what I'm given. What would be the best cam build bang for buck
Old 03-13-2014, 10:33 AM   #14
baddbradd's Avatar
three post up, samuelsmith, posted a good one
2001 coupe
Old 03-13-2014, 10:35 AM   #15
Veracadoro's Avatar
Awesome
Old 03-13-2014, 11:16 AM   #16
h1ck55ter's Avatar
you could just get a DOHC 6er and drop it in
h1ck55ter is offline   Reply With Quote
Old 03-13-2014, 11:22 AM   #17
davidcseifert's Avatar
Region: Arkansas
*218/226 .5/.5 110lsa*
blower/new cam soon
Old 03-13-2014, 11:24 AM   #18
2 Stangz's Avatar
Region: Nevada
Forget building your sixxer or dropping a DOHC v6 in (unless it's the 3.7 cyclone) just drop in the 4.6 2v and mod that one.
Old 03-13-2014, 11:25 AM   #19
h1ck55ter's Avatar
David!!! nice to see you my friend!
Old 03-13-2014, 11:27 AM   #20
Region: Arkansas
2 stangz it's not worth the money to swap, buy another car if you want a V8..
And hello
blower/new cam soon
Old 03-13-2014, 11:29 AM   #21
h1ck55ter's Avatar
Its a better feeling you get when you beat someone with a V6, let alone the feeling you get when you lose to one!
Old 03-13-2014, 02:57 PM   #22
97-04 4.2L
185/194 .443/.445 112LCA 110I
I KNOW YOU TOLD ME 110 , BUT 4.2 specks say it is 112 LCA. I was going to pm you back about that, but I am kind of confused. I don't know the difference in lca and lsa. I was kind of confused. I understand ,(LOBE SEPARATION ANGLES) (LOBE CENTER LINE ANGLE) I know lsa basically is how long the valve is open.
Old 03-13-2014, 05:00 PM   #23
Region: Arkansas
I thought they were 112lsa cores too, that's why I chose it as a base, but the grinder said its 110 and same with another cam from a 4.2 that I just sent in, both 110lsa.
I don't know where you keep getting that duration from though lol
blower/new cam soon
Old 03-13-2014, 05:02 PM   #24
Region: Arkansas
Lsa is the separation from intake to exhaust valve
blower/new cam soon
Old 03-13-2014, 05:24 PM   #25
Advanced noob mistake LOL
Old 03-13-2014, 05:28 PM   #26
Region: Arkansas
Eh doesn't hurt anything, plus makes it cam harder which is a plus
blower/new cam soon
Old 03-13-2014, 07:59 PM   #27
baddbradd's Avatar
David, the cam in your sig: what is the operating range. Too big for a daily driver with 410 gears. I know on a v8 that cams duration would be a good bottom end and great midrange. Just our smaller cubes was why I was wondering
2001 coupe
Old 03-13-2014, 08:12 PM   #28
Region: Arkansas
According to comp 1800-6200, I can say that the peak is very true, but with a stall and gears I can't speak for low end much haha I daily drove the car for a while and had no problems, still gets ~20mpg average too. New cam is gonna be a lot bigger! 226/234 blower cam ftw
blower/new cam soon
Old 03-13-2014, 08:26 PM   #29
lemons95's Avatar
If he had a 4.6 sohc V8, he could of swapped some 4.6 dohc heads on it.
The 3.8 is a pushrod engine, simpler and cheaper to swap cams with. If it was dohc you'd be spending $4000+ just for cams. With a pushrod engine it'll be closer to $1000 or cheaper for the whole kit(lifters, pushrods etc...)
Old 03-13-2014, 08:28 PM   #30
Region: Arkansas
$4000
O_O
hell I don't think Luis even charges $900 for 4V cams, install isn't that bad on top of it
blower/new cam soon
Old 03-13-2014, 09:15 PM   #31
baddbradd's Avatar
thanks David
2001 coupe
Old 03-13-2014, 09:35 PM   #32
lemons95's Avatar
well, from compcams it's $1300 for just the cams.
it's usually $300 for one cam, if it's a pushrod.
So it's still pretty expensive to go with dohc, I'm not really seeing any benefits of OHC, unless it's an inline 4 or 6 cylinder, then'd i'd probably want sohc.
OHC engine also weight more, so unless you built it to rev beyond the limits of a pushrod(which can be pretty high if built right) it would be better just to keep the stock V6 heads, and probably port them later on.
Old 03-13-2014, 10:00 PM   #33
baddbradd's Avatar
I believe this has went past way off topic lol
2001 coupe
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
Flowmaster dual exaust kit for v6? austinray4142 Pre-2005 V6 Mustang 4 08-04-2011 10:20 AM
Convert v6 to dual exhaust Redmustang2007 2005-2010 V6 Mustang 14 07-19-2011 11:25 AM
08:52 PM
