Super coupe into a 96 - Mustang Evolution
Old 03-13-2014, 10:14 AM   #1
mummert_96v6's Avatar
Ok so I want the 4.2 swap and I've been drooling over one for awhile now but I found a supercoupe motor and trans in a junkyard that's been there for awhile and I'm wondering what's easier the supercoupe or the 4.2? What all would I need to put the supercoupe motor into my 96 sixxer. I know there probably has been a bunch of these threads but I just didn't feel like looking for one
mummert_96v6 is offline   Reply With Quote
Old 03-14-2014, 01:32 PM   #2
lemons95's Avatar
I think it's only like a 20 HP difference between the supercoupe 3.8 and the 4.2.
You could do both, but the 3.8 single port heads don't flow as well.
I think with a few mods a NA 4.2 would be beating the stock supercouple.
Old 03-14-2014, 01:35 PM   #3
lemons95's Avatar
As for swapping, they'd be close to the same in difficulty, I think you need an intercooler for the supercoupe.
Transmissions are the same, unless they beefed up the internals of the supercoupe trans or it has less miles, I'd keep your stock mustang trans.
Old 03-14-2014, 01:41 PM   #4
davidcseifert's Avatar
Region: Arkansas
Huge tq difference with the blower on supercoupe, not to mention upgrades are easier and the bottom ends are tons stronger in stock form. 4.2 > supercoupe in being easy to install no doubt, but supercoupe will be much more powerful than an N/A 4.2 with little work
blower/new cam soon
Old 03-15-2014, 08:24 AM   #5
What all would I need I change though to put that motor in my car? And keep my car obd 2. And the supercoupe trans if I'm not mistaken has a hydro clutch mustangs are cable
Old 03-17-2014, 01:43 AM   #6
lemons95's Avatar
Well I think you would still use your ECU and harness. So it would still be obdII. The supercoupe transmission is PROBABLY stronger, beefed up a little to withstand the torque from the supercharger.
Old 03-17-2014, 11:22 AM   #7
Yes the trans is stronger it's stronger then the gt trans but it's hydro clutch not cable
Old 03-17-2014, 04:00 PM   #8
So does anyone know what needs to be done ECU and harness wise to get this swap done?
Old 03-17-2014, 07:07 PM   #9
samuelsmith's Avatar
You will gain 17 hp and forged internals. Make sure the firing order is the same and most parts should interchange. Since you are just putting the engine in.
Old 03-25-2014, 11:36 AM   #10
Could I just use the supercoupe engine harness with my mustang ECU and dash harness
3.8 2003 mustang Mollett1985 Pre-2005 V6 Mustang 10 01-08-2013 02:18 PM
Fun Ford Weekend and Super Chevy Shows Welcome Aeromotive Fuel Systems as Series Spo FunFordWeekend At the Track 7 02-09-2012 07:02 PM
Does any1 know how much horsepower can the internals of 1996 3.8l take?? M_PZoe Pre-2005 V6 Mustang 16 12-19-2011 09:37 AM
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
Super coupe cranskhaft Stubzmekenzie Pre-2005 V6 Mustang 3 10-06-2011 12:10 AM
05:54 AM
