2004 ford mustang v6 differential oil - Mustang Evolution
Old 03-13-2014, 05:48 PM   #1
crazybox1918's Avatar
I need to change the differential oil on my 2004 Ford Mustang V6, I've been recommended 75w140 and 80w90 Royal Purple, so I don't know what to use
crazybox1918 is offline   Reply With Quote
Old 03-13-2014, 07:28 PM   #2
PRoss.20's Avatar
Region: Arkansas
Check your owners manual. It should tell you. Then just take the differential cover off, wipe it out, and put the new oil in until a small, slow stream trickles out the top. Hope this helps.
PRoss.20 is offline   Reply With Quote
Old 03-13-2014, 07:55 PM   #3
samuelsmith's Avatar
Your Mustang's rear axle could have 75W-140 or 80W-90 viscosity gear lube. It's important to use the correct viscosity to avoid wear damage. The guide says the differential for the Cobra R Mustang has a Ford recommended viscosity of 75W-140 and the other two differentials, controlled slip and standard, Ford recommends 80W-90. If your car takes the 80W-90, the hot ticket in a synthetic gear lube is the 75W-90 viscosity and will provide better protection for your rear end. Motorcraft is the OEM standard.
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
Useful Mustang Information - READ THIS FIRST! Trojan Horse 1979-1995 Mustang GT 24 11-19-2012 09:54 PM
Good Information Thread. ESG642T Pre-2005 V6 Mustang 10 01-13-2012 08:00 AM
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
04:27 AM
