My car is slowly dying - Mustang Evolution
Old 03-13-2014, 09:09 PM   #1
I have a Manual 2001 v6. 130,xxx miles, seemed to be in good shape.
Issues that have arisen:
Alarm will no longer sound, even when I click the key fob.
Horn no longer sounds when locking it twice.
Dash will flicker and sometimes completely go dark when the dimmer is at full on.
Has failed to start more than once, and there is a clicking under dash immediately after a failed start.
Trunk no longer opens with the key fob.
This is everything I can think of right now, I know not all of these are related and possibly none are related to each other. Any ideas on where to start? I've already check every single fuse. I'm at a loss and out of my realm. Thanks in advance.
Sent from my MB865 using Mustang Evolution mobile app
alexfraley is offline   Reply With Quote
Old 03-14-2014, 06:23 AM   #2
black04v6's Avatar
Replace the battery in the key fob?
black04v6 is offline   Reply With Quote
Old 03-14-2014, 06:26 AM   #3
Yeah, I tried it, but it's both key fobs.
Old 03-14-2014, 10:53 AM   #4
samuelsmith's Avatar
Mustang Ignition Starter Switch (99-04 All) - Free Shipping
Buy this ^ to fix the starter. BTW this goes under the steering column and is the noise you are hearing.
If the horn does not work the alarm will not work but the lights should flash. Are your lights flashing?
If you do not here a loud click when you try to open your trunk you need this->http://www.ebay.com/itm/1999-2004-FO...dde576&vxp=mtr
The solenoid went bad. Or does it open when you push the glove box button?
Old 03-14-2014, 11:46 AM   #5
baddbradd's Avatar
clean and check electrical connections and batt. cables
2001 coupe
baddbradd is offline   Reply With Quote
Old 03-14-2014, 12:15 PM   #6
OfficialMakkyZ's Avatar
If you do not here a loud click when you try to open your trunk you need this->1999 2004 Ford Mustang Trunk Lock Latch Used | eBay
+1 to this.
Not exactly sure what the deal is with the key fobs if the batteries were replaced..
OfficialMakkyZ is offline   Reply With Quote
Old 03-17-2014, 04:41 PM   #7
whiteshirt99's Avatar
I would just check wiring sometimes it just goes bad and check connections
whiteshirt99 is offline   Reply With Quote
Old 03-17-2014, 06:59 PM   #8
Could it be a new locking mechanism is needed? That's what everyone says. With my car, I press the door panel L/UL buttons and it still doesn't work.
Check out my garage:
http://www.mustangevolution.com/forum/f376/t351203/
Old 03-17-2014, 09:03 PM   #9
Could be connection to the panel it's self how the wires plug into the buttons
Old 03-17-2014, 09:08 PM   #10
Or the rubbers inside the locks are worn down which can give it a bad connection
Old 03-17-2014, 09:19 PM   #11
TheBandit's Avatar
These cars had a problem with the dimmer switches going bad. Replace the dimmer switch to fix the dash lights going out.
Good luck.
TheBandit is offline   Reply With Quote
Old 03-17-2014, 09:35 PM   #12
Jaytraeg's Avatar
With the dim lights and not starting every now and then, it almost sounds like a bad battery/alternator...
Jaytraeg is offline   Reply With Quote
Old 03-19-2014, 06:21 AM   #13
Well, when I press my L/UL, the locks move. They try to work, but I guess don't have enough power lol
Old 03-21-2014, 01:30 PM   #14
sounds like batt/alt. all these require power to work
K.Ledford is offline   Reply With Quote
Old 03-21-2014, 02:01 PM   #15
Thanks for your reply!
I also thought it was the battery or alternator. Went to autozone and had both tested. Battery tested bad, but alternator tested good and strong. Got a new battery and the problem persists. I'm starting to think it's the actual mechanism. Might need some lubin' up or something. I'm taking my door panels off for a repaint anyway, so I'll take a look and get back to you guys about it so everyone has an answer.
First Car, Hi there :D Jetsnix New Member Introductions & Greetings 14 08-20-2014 06:05 PM
Favorite previous car you have owned Ish416 General Car Discussion 25 03-27-2014 12:29 PM
A Mustang that you DO NOT WANT olds442111 General Mustang Discussion 45 03-18-2014 06:34 PM
Mustang 2 motor swap. Curtiswhitehead 2.3 Mustang 2 07-10-2013 08:06 AM
my car will die and start right back up again! HELP Josh.0 Pre-2005 V6 Mustang 25 06-07-2012 11:47 AM
11:51 AM
