Changed my mind about scing my car.. - Mustang Evolution
Old 07-29-2008, 11:52 PM   #1
jmp782's Avatar
Hey all, After a lot fo thinking and the like, I decided against scing my car. I am thinking I want to keep the car NA and go with a h/c/i package. I was wondering how much is the average price to get heads, and upper and lower intakes ported and polished? What about install? I am assumign thats an expensive piece of work....any ideas so i know what to save up?
Also, Aside from the H/C/i, what other parts are needed for the install? Any other work you recomend being done? Beeft up the rest of the internals? Or is this not needed and is it safe to keep everything stock except for the H/C/I package?
I am probably going to troll the forums and buy the parts as they show up...is this a bad idea? Will this give me parts that won't flow or work as well together? Or would you reccomend buying everything as a set?
Any idea of power output when all done?
Statues show us what people looked like....if birds shat on them....
jmp782 is offline   Reply With Quote
Old 07-30-2008, 08:44 AM   #2
Re: Changed my mind about scing my car..
the price varies depending on which you go with~ I would probably see around 2k for everything needed and then assume labor will be 1-2k depending~ I personally would do a 4.2 stroker at the same time which will be another 2-3k lol... it adds up quick
Old 07-30-2008, 11:22 AM   #3
Send a message via AIM to VCS_SSSTANG
Depending on your power goals, slapping a s/c on the car may be cheaper in the long run.
VCS_SSSTANG is offline   Reply With Quote
Old 07-30-2008, 01:39 PM   #4
Herbstang's Avatar
Good point
Old 07-30-2008, 04:44 PM   #5
jmp782's Avatar
I would like to keep the car NA if possible. If I did ported and polished heads and intakes and then a new cam, wouldn't that be a "safer" set up for a daily driver?
Old 07-30-2008, 05:12 PM   #6
1234's Avatar
Not really. A sc with a good tune is just as safe.
Old 07-31-2008, 06:24 AM   #7
Herbstang's Avatar
With all the money you'll spend on H/C/I and labor cost you can pick up a S/C or turbo Kit (If you shop around) and as stated as long as you get a safe tune your bottom end will be fine.
You maybe disappointed in the HP gains on a 3.8 IMO you may see 220 to 230 RWHP Now a 4.2 with super six stage 2+ N/A has seen 260 RWHP
Old 07-31-2008, 01:47 PM   #8
jmp782's Avatar
thanks for the info. I will take a look at pricing and the like and go from there. Good point on the sc vs h/c/i price. Anyway, engine has about 84k on it, that too much to slap a scer on it? Also, with a SC, would I have to upgrade my internals at all?
Mind F%$k sonicpony03 Pictures and Videos 19 07-22-2010 11:07 AM
What comes to mind... PureVenom Pictures and Videos 17 10-01-2006 11:35 PM
Made up my mind!! Danger Dude Pre-2005 V6 Mustang 39 03-10-2005 06:03 AM
Dont mind me...... 03redfire cobra The Bar 84 01-27-2005 11:01 AM
09:00 AM
