GT rear end swap - Mustang Evolution
Old 03-17-2014, 01:23 PM   #1
PRoss.20's Avatar
Region: Arkansas
GT rear end swap
I have been wanting to do a GT rear end swap for so long on my mustang, but I have been having a lot of trouble finding one and I have no idea on pricing. I saw some on eBay for like 600 bucks with a lot of miles on them and I was thinking that is way too much. Any suggestions on finding one and can anyone give me an idea of how much I should be paying for one based on how many miles it has on it?
PRoss.20 is offline   Reply With Quote
Old 03-17-2014, 01:32 PM   #2
h1ck55ter's Avatar
dosnt really matter the miles on it cause you can buy the gears you want and you can swap your axels from your 7.5 rearend in to the 8.8, as long as the rearend your getting is still 28 spline. but i got my mach1 rear end for 350, just go to the junk yard and pull one, you dont just need to get it from a gt, or a mustang at that.
Polished heads, stock lower, 3.8 bottom end, Mac Pro Dumps, Mac O/R H-pipe, Pacesetter lt's, SCT xf3 (93 Ortizperformance tune), 03-04 Cobra tb, Lightning MAF, BBK CAI, Stage 2 water/meth kit, 310 LPH Fuel Pump, 39lbs blue top injectors, Mach 1 8.8 w/ 3.55's, steeda springs 1.5", Bilstien shocks/struts,Steeda Caster Camber Plates, M112 blower w/ 3.1 Pulley
h1ck55ter is offline   Reply With Quote
Old 03-17-2014, 02:02 PM   #3
Milehigh STK's Avatar
Bought mine on craigslist for $275 with 40k miles then paid $200 to install 4.10 gears
Milehigh STK is offline   Reply With Quote
Old 03-17-2014, 02:03 PM   #4
PRoss.20's Avatar
Region: Arkansas
I guess I have no luck on Craigslist. I never can find one in my area!
Old 03-17-2014, 02:19 PM   #5
It took me a while too. Just gotta keep checking. The add May not be a straight up 8.8 rear. Mine was labeled something like mustang parts (99-04) and it had several things and i just picked out the rear end!
Old 03-17-2014, 02:21 PM   #6
Also, like the other guy said try junkyards! You can get them even cheaper.
Old 03-17-2014, 02:21 PM   #7
PRoss.20's Avatar
Region: Arkansas
So is it only 99-04 year ends that will fit my 04? Or can it be 95-04 because that would help broaden my search.
Old 03-17-2014, 02:23 PM   #8
I believe the older years will work but are slightly longer. There is some kind of length difference. I'm sure it's said somewhere in one if the 8.8 swap threads. I'll go see if I can find it
Old 03-17-2014, 02:24 PM   #9
PRoss.20's Avatar
Region: Arkansas
Thanks, because I found one that said 96-02 rear axle with 3.73 gears already in it and I'm wondering if that would fit.
Old 03-17-2014, 02:29 PM   #10
Originally Posted by lemons95 View Post
You need the whole 8.8 rearend, bolts in with no modifications...
a 94-04 rearend would work, I use a 2001 GT rear end under my 1995 V6. I think it's about half and inch wider? everything still bolted up with no problems though.
It'll be hard to find one with the gears you want, I don't know about 94-98 GT's but the 2001 I got had 3.27's stock, better than the stock 2.73's.
This is on another thread. So it would be half an inch tucked I guess!
Old 03-17-2014, 02:31 PM   #11
PRoss.20's Avatar
Region: Arkansas
Hmm I wonder if that would look bad or noticeable
Old 03-17-2014, 02:32 PM   #12
96-02 is weird though. Does that mean they have a couple of rear ends ranging from those years? Are you sure it's off a mustang?
Old 03-17-2014, 02:39 PM   #13
PRoss.20's Avatar
Region: Arkansas
1996 to 2002 Mustang gt rear end with 373 gears. 450.00 obo
This is exactly what the ad say :p I emailed him asking what exact year the rear end is from because of the weird year range.
Old 03-17-2014, 02:52 PM   #14
The miles shouldn't really matter because when you install the gears you should prolly rebuild it anyways
CoyoteEatsBirds is offline   Reply With Quote
Old 03-17-2014, 03:08 PM   #15
Yupp. Bearings are cheap insurance. As long as the housing is straight who cares.
Sent from my massive johnson.
Old 03-17-2014, 03:10 PM   #16
PRoss.20's Avatar
Region: Arkansas
What do you mean rebuild it?
Old 03-17-2014, 03:48 PM   #17
450 is a good price for already having gears installed. As long as the 3.73 are what you want in it!
Old 03-17-2014, 04:41 PM   #18
2000stanguy's Avatar
Just to clarify 94-98 8.8's will fit but are 1.5" shorter in overall length. It looks a little funny and is defiantly noticeable. They also have lower gear ratios either 2.73 or 3.08 depending on what model it is from 99-04 will fit perfectly and has higher gear ratios 3.27 for Gt and 3.55 for the Mach 1.
Performance Red 2000 v6- m112 supercharger,42lb green top injectors, 310lph fuel pump, BBK shorty headers, True dual exhaust, strut tower brace, GT rear sway bar, Steeda triax short throw shifter, SR lowering springs, tinted headlights and foglights, polk audio speakers, MTX subwoofer, Kenwood head unit and black leather interior.
2000stanguy is offline   Reply With Quote
Old 03-17-2014, 08:10 PM   #19
Well there you go!
Old 03-17-2014, 08:42 PM   #20
So u guys would recommend doing the gt swap than buying a tloc and get both of them spinning through that
Old 03-17-2014, 09:47 PM   #21
The GT rearend can often be found cheaper than a t-loc and is stronger. If you can get a deal on a t-loc and don't plan to go fi or add a lot of hp you will be fine with a t-loc.
Old 03-17-2014, 09:52 PM   #22
It's cheaper isn't it? An you upgrade to an 8.8 just in case you want to push more power.
Old 03-17-2014, 09:53 PM   #23
Oops his reply didn't show up till I posted! Also have to take into account the cost to get the tlock installed
Old 03-18-2014, 04:07 AM   #24
thanks for the info soon as im done with exterior mods will be searching for a t-loc
Old 03-18-2014, 07:59 AM   #25
PRoss.20's Avatar
Region: Arkansas
T-locs are expensive from what I have seen. Just get the rear end.
Old 03-18-2014, 09:27 AM   #26
Traction lok aka limited slip. I got the carbon fiber clutch packs new and installed that when I installed my gears. It's good insurance cuz you don't know the condition of the old one
Old 03-18-2014, 12:44 PM   #27
baddbradd's Avatar
I bought a complete stock 97gt rearend a few weeks ago...$200. It has a stock t-lok. 7.5 diff. was over $400 plus gears
stock 8.8 found some 4:10s for $70 shipped.
The donor car was an auto with 100k miles. I'll replace the t-lok down the road WHEN needed. So, for me it was cheaper to do this 8.8 swap.
Lastly I bought 3" ARP wheel studs because I'm gonna get some 1" wheel spacer to offset the diff. Later one day, I can do wheels with a bigger offset
2001 coupe
baddbradd is offline   Reply With Quote
Old 03-18-2014, 12:45 PM   #28
baddbradd's Avatar
An 8.8 from a gt will have a tlok STOCK--but who knows the condition
2001 coupe
Old 03-18-2014, 01:03 PM   #29
Yea I'm look into the 8.8 rear ends
Old 03-18-2014, 01:04 PM   #30
baddbradd's Avatar
for me it was the cheapest way out
2001 coupe
Old 03-20-2014, 01:30 AM   #31
lemons95's Avatar
I bought a wrecked 01 GT, planned on engine swap. I just ripped off the cai, rear-end then sold it though. Only paid $280 for it.
The wider rear-end gives my 95 a little bit cooler stance.
It would look weird putting a 94-98 on a 99-04 though.
So make sure it's the 99-04 8.8's
Old 03-20-2014, 06:47 AM   #32
2000v6_Nat's Avatar
Region: Nebraska
I'm planning on eventually doing an 8.8 GT swap on my v6. What's the difference between the 3.73 and 4.10, would it affect my mpg or anything like that?
No engine/performance mods (yet). Mach 460 sound system, 2 12" alpine subwoofers in a custom box w/ 1800watt kenwood amplifier. Smoked halo headlights, smoked sequential taillights, black bullitt staggered rims, racing stripes, and plastidipped spoiler. Future exterior mods - Chin spoiler, black fuel door, and demon fender flares (plastidipped).
2000v6_Nat is offline   Reply With Quote
Old 03-20-2014, 08:45 AM   #33
lemons95's Avatar
Well 4.10's would be the best for drag racing. Don't know anything about mileage though.
Old 03-20-2014, 09:28 AM   #34
h1ck55ter's Avatar
The gear ratio allows for diffrent acceration, lower the gear ratio (bigger the number) the faster you accel. down side is you will be in higer rpms when driving for dd use. i have 3.55 and i avg 20mpg, when i had 4.10 I had an avg of 17mpg, and if i had 3.73 you could gusse i would have about 18-19mpg, but it all depends on what mods yo uhave and tune. but you will hurt mpg with higher gear ratio.
Old 03-20-2014, 09:33 AM   #35
h1ck55ter's Avatar
And if you find a mach 1 rear end, like i did it comes stock with 3.55's and carbon fiber clucth t-lock.
Whine in the rear end Blovett55 Pre-2005 V6 Mustang 21 07-06-2013 07:28 AM
Interior lighting SWAP (01 GT) ThePhantom General Mustang Discussion 7 12-09-2011 05:25 PM
Rear end clunk Brad.krieg SVT Mustang 3 12-08-2011 12:05 AM
5.0 swap into a 98 gt???? 98allblkgt 1996-2004 Mustang GT 6 11-23-2011 05:55 PM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
11:45 PM
