EGR delete? - Mustang Evolution
Old 03-18-2014, 01:32 PM   #1
Xaperez100's Avatar
EGR delete?
What exactly do i need
Someone can explain to me how to do it with instructions ? Please and thanks
Xaperez100 is offline   Reply With Quote
Old 03-18-2014, 01:52 PM   #2
baddbradd's Avatar
u need a tuner to turn off the cel...you will get a code
block off bunger from exhaust manifold. blockoff plate on the front of the intake where egr mounts
2001 coupe
baddbradd is offline   Reply With Quote
Old 03-18-2014, 02:07 PM   #3
Xaperez100's Avatar
I already have a code from it anyways lol I replaced it and still throwing code.
But what about the two hoses going into the little rectangular metal box sorting there with the sensor on it?
---------- Post added at 03:07 PM ---------- Previous post was at 03:07 PM ----------
Where do I get the block off plates?
Old 03-18-2014, 02:13 PM   #4
samuelsmith's Avatar
VMPtuning.com sells the delete. 15/16 " wrench will remove the pipe. I had to cut my wrench or remove the pass. side exhaust manifold to remove the egr.
Old 03-18-2014, 02:13 PM   #5
baddbradd's Avatar
I just got my egr mount and cut out some scrap metal(1/8" thick), drilled 2 holes. bolted it up with some permatex. That blocks off the intake. Undo the entire tube that bolts to the header, on my 01 last primary pass. side. I stuck a bolt init and welded the hole shut. Then I capped off the vacuum tubes, removed the sensor and HID the wire connectors. Don't cut them. If I had to re-add it, I could. I notice no lose in fuel mileage.
I did it to clean up engine bay AND make room for my windstar intake.
2001 coupe
Old 03-18-2014, 03:50 PM   #6
Xaperez100's Avatar
If I remove it and don't delete the code will it mess anything else up? Or do I need to delete it?
Old 03-18-2014, 03:57 PM   #7
Your check engine light will come on. Just remember that code is not effecting any thing important. The egr sends exhaust gasses back into the intake. You can also put a pipe stop on the manifold.
Old 03-18-2014, 03:59 PM   #8
Xaperez100's Avatar
Yeah I was thinking of just buying the pipe stop and then a 1/8 plug for the Egr part then that's it lol
Old 03-18-2014, 04:23 PM   #9
2000stanguy's Avatar
If you delete it would you not pass inspection?
Performance Red 2000 v6- m112 supercharger,42lb green top injectors, 310lph fuel pump, BBK shorty headers, True dual exhaust, strut tower brace, GT rear sway bar, Steeda triax short throw shifter, SR lowering springs, tinted headlights and foglights, polk audio speakers, MTX subwoofer, Kenwood head unit and black leather interior.
2000stanguy is offline   Reply With Quote
Old 03-18-2014, 04:47 PM   #10
Xaperez100's Avatar
I got the hook up with inspections anyways:p
Old 03-19-2014, 06:00 AM   #11
baddbradd's Avatar
I don't 'think' you'd pass visual inspections. We don't have it here
2001 coupe
Old 03-20-2014, 10:11 AM   #12
h1ck55ter's Avatar
i used a quarter and rtv and put a custom plate on. works like a champ. Only cost me .25 cents!
Polished heads, stock lower, 3.8 bottom end, Mac Pro Dumps, Mac O/R H-pipe, Pacesetter lt's, SCT xf3 (93 Ortizperformance tune), 03-04 Cobra tb, Lightning MAF, BBK CAI, Stage 2 water/meth kit, 310 LPH Fuel Pump, 39lbs blue top injectors, Mach 1 8.8 w/ 3.55's, steeda springs 1.5", Bilstien shocks/struts,Steeda Caster Camber Plates, M112 blower w/ 3.1 Pulley
h1ck55ter is offline   Reply With Quote
Old 04-07-2014, 04:09 PM   #13
Xaperez100's Avatar
Rtv?
egr delete Jar72 1979-1995 Mustang GT 4 02-16-2014 09:58 AM
Useful Mustang Information - READ THIS FIRST! Trojan Horse 1979-1995 Mustang GT 24 11-19-2012 09:54 PM
EGR delete - what do I need Jettin Stang 1979-1995 Mustang GT 10 10-04-2012 07:36 AM
EGR delete Storm13_5.0 1979-1995 Mustang GT 28 05-24-2012 06:16 AM
EGR troubleshooting? Nate98stang 1996-2004 Mustang GT 3 11-04-2011 01:23 PM
02:35 AM
