Advise needed. Should I buy it? Different year used 8.8 + gears/posi? - Mustang Evolution
Old 03-19-2014, 08:02 PM   #1
Lightbulb Advise needed. Should I buy it? Different year used 8.8 + gears/posi?
Alright, so I originally had plans to do exhaust but I'm not sure if this is an offer too good to pass up. I was planning to do gears in the future so this might work out. Note: I have a 2004 v6 mustang 5 spd
Searching the ole' craigslists and saw two ads.
Ad #1: 97 GT stock 8.8 rear end w/ 2.73 gears $150
Ad #2: recently 2002 GT Rebuilt Ford mustang 8.8 rear rebuilt with Carbon Clutch packs and have a set of 373 gears $125 obo posi $100 obo gears
Questions to answer:
1. The gears from the 2002 GT *would not* fit the 97 rear end correct?
2. The posi (limited slip differential right?) *would* fit the 97 GT 8.8 though, unlike the gears correct?
3. Do I even need to install a posi, does the 97 GT have one?
4. What kind of install would be required/what might a shop charge to install the posi and lets say 4.10 gears if I bought them? Thats $150 rear end + 125 posi + 140 gears + ??? for labor. (I'll try to install the rear end myself, just need the gears and posi put in)
Thanks in advance! (It'd help if each question was answered in the space between each question! )
zachsola is offline   Reply With Quote
Old 03-19-2014, 10:52 PM   #2
samuelsmith's Avatar
1. yes 86-04 pumpkins will interchange
2./3. 97 has posi
4. around $1000 for 4.10 installed
the 3.73 pumpkin will be much cheaper installed. How much? Good question. Get a quote from someone you trust because working on a rear end is a mech. version of surgery. I will take a engine apart and put it back together. I will not touch a rear end.
Trust me, people love to correct me but I am still 97% accurate.
Old 03-19-2014, 10:59 PM   #3
It cost like 800 to completely rebuild my old 2v. Get option 2
TomFromMySpace is offline   Reply With Quote
Old 03-20-2014, 01:23 AM   #4
lemons95's Avatar
Get the 02's the 97 8.8 is not as wide. The 3.73's will be plenty so just use those.
The rear-end swap is surprisingly really easy, it's just kinda heavy. It bolts right up.
I put an 01 8.8 on my 95, I think it's like half an inch difference between the 94-98 and 99-04 8.8's. I really think it made a difference in the stance of my stang though with the wider rear-end.
03:05 PM
