Gt transmission? - Mustang Evolution
Old 03-24-2014, 02:08 PM   #1
PRoss.20's Avatar
Region: Arkansas
Gt transmission?
I was wondering if I could put a 2002 gt transmission into my 2004 v6.
PRoss.20 is offline   Reply With Quote
Old 03-24-2014, 02:39 PM   #2
samuelsmith's Avatar
no way. The v-6 tranny is good 4 up 2 400 tq.
Old 03-24-2014, 03:00 PM   #3
PRoss.20's Avatar
Region: Arkansas
Well I only ask because I found a gt tranny for only 200 bucks and I am thinking of replacing mine because it's having some issues.
Old 03-24-2014, 03:05 PM   #4
The engine will never bolt up to the transmission. Auto or standard?
Old 03-24-2014, 03:09 PM   #5
PRoss.20's Avatar
Region: Arkansas
Auto
Old 03-24-2014, 03:12 PM   #6
3.9 0r 3.8?
Old 03-24-2014, 03:12 PM   #7
PRoss.20's Avatar
Region: Arkansas
3.9
Old 03-24-2014, 03:18 PM   #8
You have to find a 2004 auto that has a 3.9. 19% of 2004 have 3.8s. Unless you are good with wiring.
Old 03-25-2014, 11:42 AM   #9
mummert_96v6's Avatar
Bell housing is the same I'm not to sure about if the torque converter will bolt up but everything else should work
mummert_96v6 is offline   Reply With Quote
Old 03-25-2014, 01:34 PM   #10
lemons95's Avatar
Nope, the gt's have a 4.6 with a modular bolt pattern. The 3.8/3.9/4.2 use the older small block ford bolt pattern.
Old 03-26-2014, 10:38 AM   #11
I thought the 3.8/5.0 and 4.6 used the same bell but I was wrong sorry
Old 03-27-2014, 03:54 PM   #12
+1
Bigshow14 is offline   Reply With Quote
Can you change a manual transmission to an automatic transmission 2007 mustang? Ekon General Mustang Discussion 3 12-18-2011 03:09 AM
Automatic Transmission Question? TriStateStang Pre-2005 V6 Mustang 10 01-24-2008 12:54 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
Transmission Stuff Laser02 Pre-2005 V6 Mustang 4 11-15-2003 01:03 PM
Transmission vigiracer Pre-2005 V6 Mustang 2 07-20-2003 01:47 PM
10:07 AM
