speeddometer wont work?!?!?! - Mustang Evolution
Old 03-25-2014, 12:28 PM   #1
95convertible's Avatar
i have a 1995 mustang and for some odd reason when i bought it the speeddometer was working just fine! and now it wont work didnt know if it was a fuse or something cant seem to find anything in the owners manual if any one has anything i should try please reply!!
95convertible is offline   Reply With Quote
Old 03-25-2014, 02:12 PM   #2
samuelsmith's Avatar
Sometimes you can tap on the plastic in front of the speedometer and it will work
Old 03-25-2014, 05:41 PM   #3
Umm ok will . It's dosent move at all it it ran by a fuse or where can I find where it's ran to cause I believe there is more to it then just that
Old 03-25-2014, 06:31 PM   #4
Fuse 5 is the instrument cluster. But the whole cluster would not work if it was the fuse. Mustang Fuse Loactions and ID’s Chart Diagram – 99-04 | Mustang Fuse & Wiring Diagrams You have a speedometer cable and a gear. The cluster electronics is usually the problem. People repair them on Ebay.
My needle has to be tapped and and sometimes it sweeps. Works for me
Old 03-25-2014, 07:43 PM   #5
Ok thanks a lot for the suggestions and everything means a lot .... Love this community of mustang drivers !
Old 03-25-2014, 11:24 PM   #6
Your cool too. Sorry I can not help you any more. I only know so much about the older Mustangs. I believe the cluster can be changed out. The anti-theft did not come along till later years.
Old 03-26-2014, 06:06 AM   #7
Sometimes the speedometer won't work due to the transmission output shaft sensor not being read by your ECU. Not sure if this model mustang has a TOSS but if it does, I would look at that as well. Pretty easy to get to with the right tools, it's in the tranny case though so be careful. Most shops will look at it for you for a small fee, rather than you dropping the tranny and looking at a repair bigger than you expected.
199sixxer is offline   Reply With Quote
Old 03-26-2014, 08:32 PM   #8
anthonys98's Avatar
Send a message via Skype™ to anthonys98
Funny.. I've done that several times. Mine usually works but for whatever reason sometimes it decides not to
anthonys98 is offline   Reply With Quote
Traction control wont work Mfore33 1996-2004 Mustang GT 1 06-19-2012 08:31 PM
Left low beam headlight wont work but i will when i turn on high beams p1blake04 1996-2004 Mustang GT 4 09-05-2011 10:30 PM
high beams wont work cobragt2000 1996-2004 Mustang GT 3 01-05-2011 07:28 AM
Help Needed - Cigar Lighter wont work for 98 Mustang StreetJMusic Pre-2005 V6 Mustang 23 07-08-2009 10:52 PM
Door Locks Wont Work!! Help! NEPTALI 1979-1995 Mustang GT 4 04-26-2008 01:04 PM
06:56 PM
