Electrical - Mustang Evolution
Old 03-25-2014, 04:46 PM   #1
jessica99's Avatar
Electrical
I've got a 1999 V6 mustang that has want I think, are some electrician problems. The radio which is stalk doesn't work and I knew this when I bought, just figured I'd buy a new system etc. although since I bout the car I've had this happen to me twice. I turn on my car and the left blinker is on. No the knob is not in the down position. If I move it up into the right clicked it turns the 4 ways on but if I press the hazard button on and turn it off then it stops. Once an awhile the radio comes on and off when it wants and once in a blue moon the odometer flickers. Any ideas? At first I thought it was just the radio but now i think it may be more.
jessica99 is offline   Reply With Quote
Old 03-25-2014, 06:33 PM   #2
samuelsmith's Avatar
To fix the turn signal you must replace the multifunction switch. Autozone calls it the turn signal switch and it is $85.
Old 03-25-2014, 06:38 PM   #3
jessica99's Avatar
Alright. Thanks a lot!!
Old 03-25-2014, 11:19 PM   #4
Your welcome, my odometer always flashes. You can not replace the cluster because of the PATS system. Some people repair them on Ebay, but you would not be able to drive your car while the cluster is being repaired. The dealership can fix it but your better bring the bank with you =( The cluster has to be programed to your PATS system. I cheat the miles LOL by the odometer shutting down.
Old 03-26-2014, 07:18 AM   #5
jessica99's Avatar
Alright. Well my dad's pretty good with cars and has a mustang which he's also working on and upgrading so I'm sure he can do it so maybe I'll ask him to check it out with his mechanic buddies if it gets worse. Because it doesn't do it all the time. The worst thing is the radio flickering on and off but I'm not sure if it's electrical or just the radio is a peice of **** because it's the original one lol
Old 03-26-2014, 05:09 PM   #6
It's probably the radio. It could also be 2 powers or a ground. It's hard to tell without taking the radio out and testing the wires while the radio does not work. Probably something for your dad to look at. I am sure he has a volt meter or a test light.
Old 03-26-2014, 05:37 PM   #7
jessica99's Avatar
Yeah he can look at it and if it's just the radio then I'll just but a new one
94 GT New engine, now have weird Electrical Probs... Ideas? keebler117 1979-1995 Mustang GT 2 12-11-2007 03:43 PM
Problem with electrical system kitslik Pre-2005 V6 Mustang 4 11-29-2007 09:56 PM
Electrical Lighting megax29 Pre-2005 V6 Mustang 5 10-28-2006 03:57 PM
Higher RPM's Due to Electrical Load? Rellik Pre-2005 V6 Mustang 11 03-30-2005 09:45 AM
mechanical or electrical gauges? tedness Pre-2005 V6 Mustang 1 03-26-2005 12:44 PM
03:18 AM
