Car turns off sometimes - Mustang Evolution
Old 04-10-2014, 02:52 PM   #1
Xaperez100's Avatar
2000 mustang so I changed out my exhaust manifold because it was causing a misfire and also caused the car to lose power in 1st gear when going up hills.. It would just turn off. So I replaced it and now it runs great but now when I brake and come to a complete stop it dies but only sometimes. But it the rpms still drop to around 5-600 everytime I come to a complete stop. Most of the time it does all the way when I stop going downhill... Any one ever had this problem?
(EGR delete, Short ram intake, muffler delete)
Xaperez100 is offline   Reply With Quote
Old 04-10-2014, 02:55 PM   #2
FullyAutomatic's Avatar
Region: Mexico
does it seem to be choking for fuel?
FullyAutomatic is offline   Reply With Quote
Old 04-10-2014, 02:59 PM   #3
Xaperez100's Avatar
It just starts to die out idk why.. But when I'm sitting in place at idle it doesn't. Like it'll try to stay on but it'll die out unless I press the gas. And I can turn the car right back on. And when I lay down the pedal it picks up but after a certain rpm it opens up more.
Old 04-10-2014, 03:16 PM   #4
samuelsmith's Avatar
I would check the vacuum lines. Especially the one to the fuel pressure sensor.
Old 04-10-2014, 03:23 PM   #5
Xaperez100's Avatar
Okay
And Would egr delete affect it?
Old 04-10-2014, 03:25 PM   #6
Region: Mexico
how did u delete your egr. im interested in doing it
Old 04-10-2014, 03:30 PM   #7
Xaperez100's Avatar
Well when I bought the new manifold it came with these little screw on covers over the hole where the egr would go into the manifold so I kept those on and just bought a little rubber hose cover and put it in the egr valve itself. I'll take a picture in a bit
Old 04-10-2014, 03:52 PM   #8
Region: Mexico
thanks
Old 04-10-2014, 09:00 PM   #9
I've herd it needs to be tuned others say it just runs lean. I do not personally know. I know the egr delete is done with Windstars and long tube headers.
Old 05-03-2014, 03:32 PM   #10
ANS
Send a message via Skype™ to ANS
Could be bad injectors
ANS is offline   Reply With Quote
car spins outa control on left turns..Wth?! hepler02 Pre-2005 V6 Mustang 30 07-20-2013 11:05 AM
car just turns off Giffmastaflex 2005-2010 V6 Mustang 10 03-31-2012 09:12 AM
car turns off when disconnect battery superman1 Classic Mustangs 4 02-08-2012 08:41 PM
mustang Turns off in idle, right after turning on DG_Aviles32 Pre-2005 V6 Mustang 7 06-30-2008 04:08 PM
Sometimes you can get in, sometimes you can't Ken The Bar 3 09-02-2003 05:32 PM
02:12 PM
