87 turbo coupe rear end to 2004 mustang V6 swap!? - Mustang Evolution
Old 04-28-2014, 09:19 PM   #1
mazen123's Avatar
I was looking to upgrade my rear end to a LSD and lower my gear ratio too. I found a nice turbo coupe 8.8 rear end with a limited slip/ posi/ trac loc (whatever you call it) and with stock 3.73 gears (it was pulled from an auto). I've looked around a lot and I've done some research and it seems to be a direct bolt on to my car except it is 3/4 inches shorter from each side compared to my 7.5 axle. Is this true? Is it a simple bolt on other than the shorter ends?
mazen123 is offline   Reply With Quote
Old 04-28-2014, 09:24 PM   #2
Yea it will work, you might need to use the newer e-brake cables not 100%. Is it 4 or 5 lug.
Bigshow14 is offline   Reply With Quote
Old 04-28-2014, 09:25 PM   #3
mazen123's Avatar
It is a 5 lug, which makes it even easier right?
Old 04-28-2014, 09:33 PM   #4
Yes just unbolt your 7.5 and use your upper and lower controller arms. This would be a good time to install the rear quad shocks and gt sway bar
Old 04-28-2014, 09:34 PM   #5
Did the guy change the gears to 3.73. I think the turbo coupes came with 3.55s
Old 04-28-2014, 09:37 PM   #6
mazen123's Avatar
I was thinking of doing the sway bar but are the quad shocks worth it? Is that for comfort and softer driving on bumps and stuff?
---------- Post added at 03:37 AM ---------- Previous post was at 03:36 AM ----------
Stock autos came with 3.73s and manuals came with 3.55s
Old 04-28-2014, 09:41 PM   #7
They help control wheel hop.
---------- Post added at 10:41 PM ---------- Previous post was at 10:40 PM ----------
What wheels do you have
Old 04-28-2014, 09:42 PM   #8
mazen123's Avatar
Stock 16" rims and 225/R16 tires
Old 04-28-2014, 09:48 PM   #9
Just keep in mind if you use the quad shocks with aftermarket wheels you will need to install them backwards for clearance since the rear end being a little shorter.
Old 04-28-2014, 09:49 PM   #10
mazen123's Avatar
Alright thanks man, I really appreciate the help
Old 04-28-2014, 09:50 PM   #11
Glad I could help.
2004 mustang
turbo 3.8 v6 or swap to (turbo??) 4v dohc 4.6 v8??? morthis32 Pre-2005 V6 Mustang 95 09-07-2012 03:27 PM
Turbo Coupe swap MC770 2.3 Mustang 12 11-05-2010 12:59 PM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 03:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 06:56 PM
Can i swap my 1997 mustang gt rear end for a 1995 mustang cobra one? mathieu 1996-2004 Mustang GT 1 08-21-2009 01:40 PM
02:28 PM
