2002 Replaced Clutch Now Misfires - Mustang Evolution
Old 04-29-2014, 08:18 PM   #1
Unhappy 2002 Replaced Clutch Now Misfires
I replaced the clutch in my 2002 Mustang V-6 and the check engine light came on. The shop says it is misfiring and it may be the cylinder. I never had a problem until I replaced the clutch. Not sure what this Crank Position sensor is but could it be that? Please help I love my Mustang and I really feel the shop did something wrong to cause this or did not do something they should have. Any ideas?
2002BlkMustang is offline   Reply With Quote
Old 04-29-2014, 10:14 PM   #2
sebasflorez's Avatar
Coil pack. Does the car hesitate when accelerating?
sebasflorez is offline   Reply With Quote
Old 04-29-2014, 10:52 PM   #3
Sometimes when the check engine light flashes
Old 04-30-2014, 10:45 AM   #4
It only loses power when light flashes. Please help the shop says its a cylinder but before the clutch was replaced, ed it ran great.
Old 05-15-2014, 06:07 AM   #5
What codes are you getting? The car should have them stored even if the CEL isn't on. Apparently misfires are very common in these cars... when my car had his misfires I also got a code for the crank position sensor. It was $30 from advanced auto, very easy to replace, you'll find diagrams online, it's pretty much plug and play. Didn't fix my issue though. When my CEL would flash on the car lost alot of power, and it had horrible hesitation in general.
Replace your ignition coil first and see what happens, you may be due for a new one. that solved my issue, it's worth a try.
Miri is offline   Reply With Quote
2002 Ford Mustang: Replaced keyless entry remotes battery but now it doesn't work? jeffery 1996-2004 Mustang GT 6 02-05-2014 12:00 PM
2010 misfires 89and10stang 2011-2014 Mustang GT 8 03-15-2013 10:24 PM
Replaced dizzy now problems Outlawmack 1979-1995 Mustang GT 8 03-09-2013 08:27 PM
1995 mustang replaced the head gaskets now it wont start bkbeckelic General Car Discussion 5 04-01-2012 01:00 PM
Cold Weather Misfires? NDblackstang 2005-2010 Mustang GT 5 03-11-2008 12:14 PM
08:11 AM
