2003 steering and handling - Mustang Evolution
Old 05-03-2014, 07:44 PM   #1
xfree143's Avatar
I just got my mustang a few weeks ago. I have been driving it on the interstate and have noticed how loose the steering feels. On anything less than perfect road I can feel it wonder around in the lane and have to correct all the time.
I have looked at the ball joints but don't see any that look worn out. Is this just they way the 2003 handles?
xfree143 is offline   Reply With Quote
Old 06-24-2014, 04:59 AM   #2
From what I've seen, a lot of people first look at the rag joints in the 96-04 era mustangs. If they are fine, it seems that the steering column is what seems to have a defect. However, if you look up the method of swapping it out, you can generally find one for $40 or $50 on eBay. And it doesn't need to be the same year. It could be an 04 or even previous years.
Don't just take my word for it, look further into it. But I'm going through the same issues right now and those are the two steps I have to go through.
Let me know if that helps, I'll also keep you updated on what works for me.
~ Eric
eric512x is offline   Reply With Quote
Old 06-24-2014, 06:13 AM   #3
xfree143's Avatar
it was in my rack and pinion, once I changed that it improved a lot.
Old 06-24-2014, 06:27 AM   #4
Hard to change?
Old 06-24-2014, 07:15 AM   #5
xfree143's Avatar
not bad, I replaced the tie rod ends also since I had to disconnect those anyway.
Old 06-24-2014, 07:36 AM   #6
Able to do it all yourself?
Old 06-24-2014, 08:11 AM   #7
xfree143's Avatar
yes no problems if you have the tools. the following weekend I put in lowering springs, front and rear sway bars, and new shocks and struts.
Old 06-24-2014, 11:25 AM   #8
samuelsmith's Avatar
If you bring your car to a shop. They will tell you what is wrong with your car. Just refuse the work and do it your self.
Old 06-24-2014, 08:23 PM   #9
Until they pull the "we can't legally let it leave like this" card. Xfree make sure you do CC plates too if you haven't already or you'll be buying new front tires before long.
Old 06-25-2014, 07:44 PM   #10
xfree143's Avatar
Yes planning on adding the plates, thanks!
suspension and handling mods?? morthis32 Pre-2005 V6 Mustang 68 09-04-2012 11:14 AM
Handling and a smoother ride 1991stang 2.3 Mustang 2 07-10-2012 09:00 PM
suspension and handling Mr. SoloDolo 2005-2010 V6 Mustang 3 03-29-2012 12:09 PM
complete handling and lowering kit redfire 2005-2010 Mustang GT 5 03-22-2012 07:41 PM
2003 Ported and Spray'd Cobra vs 2003 Turbo Cobra Whipple Mustang GT vs FRC Corvette BoostedB18c Pictures and Videos 0 06-07-2008 10:07 PM
06:20 AM
