Squeak coming from front end??? - Mustang Evolution
Old 05-05-2014, 05:37 AM   #1
SLiM2775's Avatar
I have a squeak coming from the front end when I turn the steering wheel at low speeds and sometimes when going over speed bumps. It doesnt do it when I push on the front of the car thou so I dont think its a bushing. Im thinking it might be my power steering pump?? If anyone has any advice on how to find where it is coming from that would be great. Thanks in advance.
SR CAI
JVC Head Unit, 1000 Watt Pioneer Amp, Two 10" Pioneer Subs.
SLiM2775 is offline   Reply With Quote
Old 05-05-2014, 07:41 AM   #2
mazen123's Avatar
Nope its either your strut mount or ball joint. I had the same exact problem in the winter! How many miles on your car? And are the ball joints/ strut mounts original?
mazen123 is offline   Reply With Quote
Old 05-07-2014, 05:23 AM   #3
SLiM2775's Avatar
It has 173,000 on it, and I think they are the original, but I could be wrong I bought the car used. How hard would they be to replace? And I am not a mechanic, I work at a Quick Lube place where we do have a lift. If I wanted to have a garage do it what would you think they would charge for something like that, I know it all depends on where I go, I just need a ruff idea so I know I am not getting ripped off, Im taking it to be inspected on Friday so I am gonna have them take a look at it and go from there. But if its a easy job that can be done in a day without special tools then maybe I could try it myself. Any advice would be great.
SR CAI
Old 05-07-2014, 05:25 AM   #4
mazen123's Avatar
Itll be around 100-150 installed. It could also be your strut mounts, which would be around 150-200 installed
Old 05-07-2014, 05:27 AM   #5
mazen123's Avatar
I had strut mounts installed for about 180 and both ball joints installed for around 100 each. They all went bad because of the gruesome winter we had, the cold temperatures dried out the lubrication of the joints and mounts causing them to die prematurely, they were getting old though, i have 100,000 miles
Old 05-08-2014, 04:52 AM   #6
SLiM2775's Avatar
Thats not bad, but how come it only does it when the car is warmed up and only at low speeds and while not moving??? And if I get out and push and rock the front end it doesnt make the sound at all......Im confused....
SR CAI
Old 05-09-2014, 08:59 PM   #7
mummert_96v6's Avatar
I had the exact same problem with my 96 it was the ball joint so I'd start there
mummert_96v6 is offline   Reply With Quote
Old 05-14-2014, 06:00 AM   #8
SLiM2775's Avatar
Sound is Gone?????
I just got my car inspected and he said the ball joints are still good, and also the sound went away about a week before I got inspected, and it has not come back, so Im confused, but happy. I had to put a grand out for it to pass inspection thou, it needed both rear calipers because the old ones where hanging up and I had to have both rear brake cables replaced, plus the new brake pads and a new head light housing because I had moister in the one. But my car has better pick up now that the rear brakes are not hung up!!!! It was the inside pad that was stuck on, it really only needed the driver side caliper but I figured I might as well do both.
SR CAI
Old 05-14-2014, 02:20 PM   #9
mazen123's Avatar
Good for u man, thats great
Brake/Rear end squeak?!?!?! 08mustanggt 2005-2010 Mustang GT 14 08-11-2015 11:24 PM
Weird sound coming from mid front end PISTONS8904 2011-2014 Mustang GT 9 06-10-2013 12:40 PM
86 front end into an 89 front end Beatjunkiexorge 2.3 Mustang 1 05-18-2013 07:07 PM
Squeak Noise coming from Brakes Stang23 2005-2010 Mustang GT 5 11-08-2012 11:36 AM
Passenger side rear end squeak?? SuperDave2010 1996-2004 Mustang GT 4 03-09-2010 01:18 PM
12:11 PM
