Underdrive pulleys for split port 3.8 - Mustang Evolution
Old 05-05-2014, 10:31 PM   #1
mazen123's Avatar
Where can I get an under drive kit for a 99-04 3.8 mustang? I cant find them online. I only find 94-98 under drive pulleys.
Also are they worth it? Would i notice some hp or torque?
mazen123 is offline   Reply With Quote
Old 05-06-2014, 04:19 PM   #2
samuelsmith's Avatar
The maxim gain is 10 hp. But if you do not regularly rev your engine to 7000 rpms you will only see a hp or 2. Basically you can rev your engine up higher and faster with a udp. But I love mine and it's better to know the truth before you buy.http://www.rpmoutlet.com/musv6asp.htm
single port or split port 97 stang Pre-2005 V6 Mustang 8 10-10-2008 06:51 PM
single port to split port conversion NorwegianMustang Pre-2005 V6 Mustang 3 06-19-2006 03:19 PM
Split-port sheet-metal intake ericstanley Pre-2005 V6 Mustang 1 05-12-2004 04:45 PM
99^ split port camming and tune dyno results... (NO PORTING!!!) RGR Pre-2005 V6 Mustang 6 04-09-2004 07:07 AM
My terminology for single port and split port RGR Pre-2005 V6 Mustang 0 01-03-2004 10:03 AM
03:34 PM
