Power steering whine - Mustang Evolution
Old 05-12-2014, 10:41 AM   #1
mazen123's Avatar
I've read a ton about the power steering whine of the 99-04 mustangs. I'm about to finally take action and try a full power steering flush with mercon V ATF. I was wondering who has had the whine and successfully gotten rid of it?
mazen123 is offline   Reply With Quote
Old 05-20-2014, 10:02 PM   #2
I have the same issues on my 02 please let me know what you come up with thanks manny
manny02 is offline   Reply With Quote
Old 05-20-2014, 10:04 PM   #3
mazen123's Avatar
The powersteering whine is virtually gone. I took my car to the mechanics and they found 3 leaks in my system. 1 from the return line, 1 from the pump, and 1 from the rack and pinion. They replaced all of them and flushed the system with an ATF and the whine is completely gone
Old 05-20-2014, 10:05 PM   #4
Did you have any visible leaks on the power steering system? I don't have leaks in my but the whine drives me crazy
Old 05-20-2014, 10:07 PM   #5
mazen123's Avatar
Nothing i could see but after I parked somwhere for a while a puddle would form from my ps fluid. Check ur power steering fluid, is it low? Is it black? If you have no leaks then you could try a simple flush with mercon V ATF fluid and it should quiet it down
Old 05-20-2014, 10:08 PM   #6
Any suggestions on how to flush the system? Thanks manny
Old 05-20-2014, 10:13 PM   #7
mazen123's Avatar
There are forums with pictures online for our specific cars. The basis of it is jacking the car up, removing the return line hose and letting the dirty fluid drain out, then while the bad fluid is draining out, have someone start the car, and turn the wheel side to side to get more dirty fluid out....while they are turning the wheel side to side, you should pour the new clean fluid in the reservoir (never ever let it go empty) , finally, once you see new fluid exit the draining return line, your system is flushed. Fill the reservoir to the fullest, then turn the wheel side to side a little more just in case you have any air in the system
Old 05-20-2014, 10:15 PM   #8
Thanks will try this out this weekend manny
Old 05-20-2014, 10:16 PM   #9
mazen123's Avatar
Remember to use automatic transmission fluid. Power steering fluid is ****
Old 05-20-2014, 10:18 PM   #10
Ok use the mercron 5 right the same that goes in the tranny
Old 05-20-2014, 10:19 PM   #11
mazen123's Avatar
Yes that is perfect
Old 05-20-2014, 10:19 PM   #12
Ok thanks
Old 05-21-2014, 03:54 PM   #13
I get a little whine once I turn my steering wheel all the way either direction, is that what yours had?
Miri is offline   Reply With Quote
Old 05-21-2014, 03:55 PM   #14
mazen123's Avatar
When you turn any cars steering wheel all the way to the side it will whine. All systems whine a tiny bit, it just means they're under load or being used. But when it becomes loud on acceleration, thats when its a problem
Old 05-21-2014, 04:29 PM   #15
Ah ok. Thanks
Old 05-28-2014, 08:40 PM   #16
Ed98v6's Avatar
A lot of fords have this problem," my 94 f150 included" I read something about vacuum bleeding it and tried it, it worked on the mustang but not on the 150
Ed98v6 is offline   Reply With Quote
Old 05-29-2014, 07:22 PM   #17
Sluder4's Avatar
How much is decent quality power steering fluid?
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 05-29-2014, 09:37 PM   #18
mazen123's Avatar
Use mercon v Automatic trans fluid. Its like 5 bucks a quart
Where can I find steering damper for 66 manual steering? Daniod9 Classic Mustangs 11 11-06-2013 10:19 AM
Steering wheel shaking, power steering? toro 2011-2014 V6 Mustang 3 05-04-2013 06:31 PM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
power steering whine help? mikehailey02gt 1996-2004 Mustang GT 6 06-24-2009 09:06 PM
The Ford Power Steering Whine Of Death Siraco Pre-2005 V6 Mustang 8 10-21-2007 04:52 PM
04:19 AM
