HELP. Vacuum line connection broke - Mustang Evolution
Old 05-12-2014, 07:41 PM   #1
IWstangboy03v6's Avatar
I am in the process of switching all of my vacuum lines and hoses to red on my mustang. I got to the two hoses on the passenger side that connect to a plastic box with two fits coming off if it and I broke on. This box is behind the alternator. Does anyone know what this is called ?
Sent from my XT1080 using Mustang Evolution mobile app
IWstangboy03v6 is offline   Reply With Quote
Old 05-12-2014, 07:43 PM   #2
samuelsmith's Avatar
I just glued mine into a splitter. The ones on the passenger side go to the ac and blend door. Take a pic of the box behind the alternator.
Old 05-12-2014, 08:00 PM   #3
Is this the egr sensor ?
Old 05-12-2014, 09:19 PM   #4
Yes, it is one of the 2 egr sensors. It registers that you have back pressure in the engine. If you are not getting a code (check engine light on) don't worry.
Old 05-12-2014, 09:31 PM   #5
Okay I will check it tomorrow. Thank you for the help
Old 05-12-2014, 09:44 PM   #6
If I get no check engine light. Should I just close of the valve that broke off ?
Old 05-13-2014, 02:52 PM   #7
I'd use a bolt because it blows instead of sucking.
Vacuum line trouble 67mustang97 1996-2004 Mustang GT 4 04-26-2013 06:26 AM
vacuum line diagram for gt40 intake FLAT BLACK GT 1979-1995 Mustang GT 0 11-22-2012 02:26 PM
sea foam + vacuum line joey18 Pre-2005 V6 Mustang 7 07-21-2012 11:28 PM
1999 Mustang 3.8L vacuum line connection help dscott4410 Pre-2005 V6 Mustang 3 06-19-2012 08:13 AM
Sea Foam in vacuum line? afree05 2005-2010 V6 Mustang 1 12-12-2011 12:23 AM
10:22 PM
